Author Topic: Steering Idler issue  (Read 1560 times)
Neil_MV6
  • Sutton Coldfield-West Midlands
« on: 08 March 2010, 19:28:12 »
I've bought my 3rd Steering Idler after experiencing play with two previous. The first was budget, the last two were as recommended by Mark...so should be quality... but there's still play. I can even feel it when I mount the idler by hand...I push it fully on but it doesn't seem to go flush/tight on the spline. When turning the steering wheel I can feel it 'click' because of the play.
I've got pretty mush zero response from the steering when turning the steering wheel about 2cm either side of centre. As I do loads of motorway miles and it's becoming really tiring.  :(
My question is: Could the spline/shaft the idler is mounted on be worn and need replacing? If so, what is it called and are they readily available?
« Last Edit: 08 March 2010, 19:28:54 by Neil_MV6 »
Richard A
  • Aldridge, West Midlands
Re: Steering Idler issue
« Reply #1 on: 08 March 2010, 19:44:25 »
Had the very same problem, I bought a complete 'steering idler unit' ie including the spindle which is bolted to the body, you never know where just the 'steering arm's' are from, good or bad.
regards
richard a
richard a
Neil_MV6
« Reply #2 on: 09 March 2010, 10:38:54 »
Bump -
Anyone know where I can get a steering idler spindle or complete unit (rather not from stealers obviously).
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 09 March 2010, 11:15:21 »
From bitter experience, I don't fit anything other than the genuine Vx idlers as complete assemblies.
Cost is around the 50 quid mark IIRC, but never had any come-back.
Tis cheaper and less hassle in the long run!
« Last Edit: 09 March 2010, 11:16:05 by Reliance505 »
