Author Topic: head gaskets  (Read 1140 times)
dave10
  • sunderland
head gaskets
« on: 10 March 2010, 19:18:54 »
i have trouble with smoke from manifold area as yove probably read in the past now today it has started to run groggy and smoke (burning) from the other side aswell could this be a head gasket problem blowing stuff onto the manifolds
Bumbazor
  • Worksop
Re: head gaskets
« Reply #1 on: 10 March 2010, 19:28:34 »
Do you mean cam cover gaskets?
Oil leaking from there will often drip onto the manifolds, burn, and smoke.
If the car is 'groggy' it might be low on oil.
Does the smoke smell accrid and bitter, or does it smell slightly sweet?
dave10
  • sunderland
Re: head gaskets
« Reply #2 on: 11 March 2010, 10:47:45 »
rocker covers just been done and are still bone dry and oil still full
Re: head gaskets
« Reply #3 on: 11 March 2010, 10:50:34 »
If VERY recent then spilt oil/old oil takes a while to burn off.
I'm assuming you have checked that the new ones are not leaking .. especially at the semi-circular cut outs at the back .. where the black sealant goes .. ??? Very easy for the passenger side ones not to seat right .....  been there got the T shirt .. :(
