Author Topic: Failed the MOT on steering idler,  (Read 1652 times)
alfie
  • Gwent
    • Mondeo Ghia estate tdci
« on: 08 March 2010, 18:34:10 »
Hi Everyone,had the dreaded pink mot failure form today.
The failure was down to the near side steering idler,fair do,it was knacked heaps of play.
Are they a problem to replace,and any of you recommend where to get one from.
Alfie.
Re: Failed the MOT on steering idler,
« Reply #1 on: 08 March 2010, 18:36:09 »
common failure, check maintenance guide section for details, get decent Vx part, don't bother with cheap patterns
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 08 March 2010, 18:39:04 »
no real problems just get a full one not just the idler, its held on by 2 bolts, and take of the joint comes off easy with the right tools. price varies from £30 -£60 for a full one. but get a proper one not a copy.
« Reply #3 on: 08 March 2010, 23:39:27 »
Easy enough job... This is the recommended part :y :y
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190371926619
alfie
  • Gwent
« Reply #4 on: 09 March 2010, 04:51:30 »
Hi,thanks for the ad,looking for a o/e last night but missed that one,all in all had a bugger of a week.
Alfie
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #5 on: 09 March 2010, 10:29:43 »
I got mine from www.aoutovaux.com   Never had any problems with it. and only paid £26 with delivery.
you could try them.
He who brakes Looses
To old to die young
MickAP
  • South Derbyshire
« Reply #6 on: 09 March 2010, 15:37:10 »
This is the part I've just fitted, delivered quickly as well.
Yes easy enough job, when you've bashed the hell out of the b****y thing with a sodding great lump hammer, to get the joint apart :-[
Don't use a ball joint splitter on that knuckle joint, some say two hammers will do the trick top and bottom. Soak in plus gas overnight if poss before attempting :y
Mick  ;)
alfie
  • Gwent
« Reply #7 on: 11 March 2010, 18:56:39 »
Hi,Just a quick update,failed to part the ball joint after a few hours of trying everything.
So I bit the bullet and found a garage to do it,cost £15 so I was quite happy with that,so retest in the morning,and then of to Brean in the van for the weekend.
Alfie.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #8 on: 11 March 2010, 19:02:58 »
That's the tapered joint from hell!
I always give it a good clout by hitting it hard with two hammers simultaneously.
Haven't failed yet mate!
