Author Topic: doors  (Read 1264 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
doors
« on: 11 March 2010, 19:51:55 »
are saloon and estate doors different? :y
scream if you want to go faster!!!
alunonhisown
Re: doors
« Reply #1 on: 11 March 2010, 19:53:37 »
I would say so. The rear ones at least.
But I am blonde so I am proably incorrect.
Bumbazor
  • Worksop
Re: doors
« Reply #2 on: 11 March 2010, 21:29:50 »
Front are the same and yes, the rears are different.
Ken L
  • Sheffield, South Yorkshire
Re: doors
« Reply #3 on: 12 March 2010, 12:27:45 »
What about the doors from different spec cars, or different years rather, i.e. pre-facelift, mini facelift and facelift? are they interchangable?
Sorry for hijacking the thread. :)
« Last Edit: 12 March 2010, 12:28:23 by Ken60 »
MutantCav
  • Gainsborough
Re: doors
« Reply #4 on: 12 March 2010, 13:11:46 »
Front doors are all the same regardless of spec, year etc...only the door mouldings are different on the facelift models...
Rear doors again are all the same on all specs but as said estate rear doors are different from saloon rear doors...and once again facelift mouldings are different to before facelift :y
To sum up...all Omega front doors the same...all Omega estate rear doors the same, all Omega saloon rear doors the same...
Only variation at all is that the mouldings on the doors are different on facelift models to the onces before that :y
« Last Edit: 12 March 2010, 13:13:43 by ShieldOfSteel »
Ken L
Re: doors
« Reply #5 on: 12 March 2010, 13:40:50 »
Ok, many thanks for clearing that up. :y
