Author Topic: Key fobs....  (Read 1022 times)
bertiecbx550
Key fobs....
« on: 09 March 2010, 20:55:37 »
I`ve just seen an uncut  and unprogrammed 2 button key fob on E-bay....How easy is it to get reprogrammed??? :y
Re: Key fobs....
« Reply #1 on: 09 March 2010, 20:57:10 »
Anyone with a tech2 can do it ... and the forum has tech2's in Nottingham, Brackley and Winchester ...  :)
or you can pay a stealer to do it .....  :(
HTH
bertiecbx550
Re: Key fobs....
« Reply #2 on: 09 March 2010, 20:59:56 »
Cheers entwood.... :y :y :y
Re: Key fobs....
« Reply #3 on: 09 March 2010, 21:05:14 »
Bought mine (spare) off ebay - make sure has transponder chip with it - got it cut foc by a tame locksmith and tb tech2'd it 2 my car.  No probs.
bertiecbx550
Re: Key fobs....
« Reply #4 on: 09 March 2010, 21:09:46 »
Yeah it says new with transponder and free instructions on how to reprogram it.... :o 8-)
Re: Key fobs....
« Reply #5 on: 09 March 2010, 21:14:06 »
and that will be how to RESYNCH it .... which won't actually work !!!
Instructions will say .. key in ignition, switch on, press lock, unlock, lock, unlock, car should lock and unlock each time. Remote will now work normally.
Probably will .... but it won't actually start the engine until the immobilisor chip is programmed via a tech 2 .. :)
bertiecbx550
Re: Key fobs....
« Reply #6 on: 09 March 2010, 21:29:34 »
Yeah i thought that too...But you confirmed it mate.....Good aye they... ;D ;D ;D ;D
Re: Key fobs....
« Reply #7 on: 10 March 2010, 00:11:31 »
make sure its the 105 blade, and correct fob for you particular Omega.
Also note that tech2 cannot do IR style fobs
Welung666
Re: Key fobs....
« Reply #8 on: 10 March 2010, 06:02:45 »
Can't the chip be added with an "My Naff Code Reader" aswell?
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
Re: Key fobs....
« Reply #9 on: 12 March 2010, 20:39:54 »
Don't think that's entirely true.
My old 2.5 needed a new key and after a LOT of messing about I found out there are 2 types of immobiliser on the '94 / '95 migs with the IR keys. One has immobiliser only; one has immobiliser and alarm. On the former you plug the tech 2 in and then just point the key at the thingy in the roof. On the latter you need a code too.
Actually, thinking about it I think it only worked with new keys. I don't think you can reprogram old IR ones.
Work is the curse of the drinking classes (Oscar Wilde)
bertiecbx550
Re: Key fobs....
« Reply #10 on: 12 March 2010, 22:01:31 »
All sorted now....My mate dismantled both fobs and re soldered them both.....Alls well in Bertie land at the mo..... ;D ;D
