Author Topic: starting and cutting out  (Read 1043 times)
unlucky vauxhall owner
  • London
« on: 13 February 2010, 12:34:34 »
Wonder if anyone has any ideas? V6 CDX 2.5. Taking 3 or 4 attempts before she starts. Also cuts out frequently when on tickover. Would appreciate any help thanks.
Re: starting and cutting out
« Reply #1 on: 13 February 2010, 12:37:05 »
could be a couple of issues, ICV (idle control valve) worth cleaning that. Worth doing a paper clip test to get the codes, you may have a 19 for crank sensor  :y
« Reply #2 on: 13 February 2010, 16:21:44 »
As ^^^^^^^^^^^^^^^^^^^^
You can also try running it with MAF sensor disconnected to prove if this sensor ok.
  • London
« Reply #3 on: 13 March 2010, 10:29:11 »
Thanks Guys ! Sorry I took so long to reply! Had a few problems to deal with recently unrelated to car. Anyway Cleaned the ICV . still same problem. So I took it back to local garage. This is where I had the crank sensor replaced last June. Turned out it was faulty. He replaced it under warranty and so far seems to be ok. Cost me nothing! www.westendlanemotors.co.uk  I feel he deserves a mention. Myself and a couple of friends have used him before recommended! Thanks again people.  :y
Welung666
« Reply #4 on: 13 March 2010, 10:30:41 »
As long as he replaced it with a genuine Vx sensor as the copies are prone to premature failure ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 13 March 2010, 19:48:02 »
as long as its a bosch or a seimans. both are o.e  :y
Hoof'land storeman.
