Author Topic: autobox staying in 3rd when hot  (Read 3255 times)
pigtown
  • swindon
« on: 11 March 2010, 20:18:48 »
My auto works fine when cold but after a half hour run down the motorway it stays in 3rd so pulling away is like having a slipping clutch. This started a month ago and I topped up the ATF and seemed to be ok for a while. Haven't checked yet but maybe there's a leak.
Anything else to look for?
unlucky alf
  • worksop, notts
Re: autobox staying in 3rd when hot
« Reply #1 on: 11 March 2010, 20:25:35 »
i take it you topped up the g/box with the engine running. ;)
pigtown
  • swindon
« Reply #2 on: 11 March 2010, 20:28:24 »
Yeah - followed the guide on here
« Reply #3 on: 11 March 2010, 20:32:35 »
Presumably you also get 'Automatic Gearbox' on the MID?  If so, ideally need to get it to someone with a decent code reader....
pigtown
  • swindon
« Reply #4 on: 11 March 2010, 20:34:22 »
No errors coming up on the display
« Reply #5 on: 11 March 2010, 20:43:56 »
What engine?
pigtown
  • swindon
« Reply #6 on: 11 March 2010, 20:45:17 »
2.2 petrol
« Reply #7 on: 11 March 2010, 20:48:52 »
2.2 petrol
Ah ha, as I suspected.
Still need to get it on a code reader though, but probably reading engine codes as well as gearbox codes.  Does the EML come on?
pigtown
  • swindon
« Reply #8 on: 11 March 2010, 20:54:18 »
The EML is not on during this problem.
Although a few weeks ago it came on and went into limp mode. I stopped, turned off the ignition and then back on and the problem had gone and been fine until now. Could this be related?
« Reply #9 on: 11 March 2010, 21:12:16 »
as said, needs a code reader on it.
pigtown
  • swindon
« Reply #10 on: 11 March 2010, 21:19:19 »
Anyone local with a reader?
I'm in Swindon
« Reply #11 on: 11 March 2010, 21:24:54 »
I'm VERY close to swindon :) and have a basic code reader, if it'll read a 2.2 you are welcome to pop over and we can try it.
Not done a 2.2 .. only V6's, but if it's OBDII then my reader will do the engine side, it "says" it will do some gearbox modules .. but it hasn't on the few cars its been plugged in to.
If you're interested give me a PM and I'll give you my number .. :)
« Reply #12 on: 11 March 2010, 21:28:06 »
GS500 will read it Nige :y
« Reply #13 on: 11 March 2010, 21:43:52 »
Ta .. thought it would ..  :)
pigtown
  • swindon
« Reply #14 on: 13 March 2010, 11:27:40 »
Entwood read the codes - thanks
He started a new thread with the codes read but no codes were associated with the gearbox.
I'm going to continue running it and see if the problem persists!
Page created in 0.038 seconds with 16 queries.
