Author Topic: 99 v's 00 body work  (Read 1078 times)
bobbilly
  • Nottingham
99 v's 00 body work
« on: 15 March 2010, 11:19:52 »
Is there a difference (other than the moulding strip, and the door cards) between the doors on a 99 model (rubber strip) and a 2000 (colour coded strip) ?
Ta.
Re: 99 v's 00 body work
« Reply #1 on: 15 March 2010, 11:25:16 »
nope, doors a physically the same in terms of metal. As you say outer strips and door cards are different, have a feeling wing mirror mounts are different too for facelift
bobbilly
  • Nottingham
« Reply #2 on: 15 March 2010, 11:31:19 »
Any idea if the rubber strip/colour coded one are interchangeable ? (I'll have to take a punt on the door mirror
but am hopeful a bit of drill/dremel work might sort it)
« Reply #3 on: 15 March 2010, 11:35:16 »
yup can be switched, quite a few people have done it, think pre-facelift ones are clipped on, but facelift bonded  :-/ Not sure, but they can be swapped  :y
« Last Edit: 15 March 2010, 11:35:29 by tunnie »
Welung666
« Reply #5 on: 15 March 2010, 12:26:59 »
OK clear a couple of things up.....
Pre and mini facelifts are bonded on.
Facelifts have a screw in each end and slide toward the front of the car to remove.
Mirror mounts are the same all through.
