Author Topic: oil leak  (Read 922 times)
malcolm1973
  • falkirk
oil leak
« on: 15 March 2010, 16:58:02 »
 :-[ just got omega v6 2.5  2001 model first one ive had usually go for 523 bmw ,but on this car once been a run with it you can see the burning oil smoke from drivers side rocker cover side down there !! is there acommon fault and where is it coming from any ideas would be a big help ,,nice car though must admit lol  ;D its covered 132000 with service history ,,,,.....
Re: oil leak
« Reply #1 on: 15 March 2010, 17:11:53 »
cam cover is leaking / blown, replace using genuine GM gaskets, and use GM's black sealant, if you DIY or have it done in garage, make sure cam cover bolts are torqued using a wrench to 8Nm!
Clean breathers will ensure the gaskets don't blow again.
Re: oil leak
« Reply #2 on: 15 March 2010, 17:45:40 »
Welcome to OOF   :)
Good write up on how to do the cam covers here .. :
http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
ALSO  good write up doing the breathers here
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
Not worth doing one without doing the other, and as said .. GENUINE ONLY .. :)
