Author Topic: Major faults  (Read 1439 times)
cambs_nige
Major faults
« on: 15 March 2010, 11:39:37 »
Hi all was driving along last night when all four dials stopped working EML, Battery and ABS lights came on and autobox stopped working.
This morning all faults are still present although my battery had drained itself overnight. Have checked charge and that is fine and also put on a new battery but my problem still exists any clues?
Re: Major faults
« Reply #1 on: 15 March 2010, 11:42:53 »
Check all fuses would be a good start? :y
Re: Major faults
« Reply #2 on: 15 March 2010, 11:43:47 »
Alternator
cambs_nige
Re: Major faults
« Reply #3 on: 15 March 2010, 12:48:33 »
yep checked all fuses in cabin and the two compartments that sit on the battery, alls fine at idle but as soon as you press the accelerator the abs light appears and all four dials drop to zero. When it first happened I suspected that the alternator was frying the battery but the garage put a multimeter on it and got a normal readout but im wondering if it would have been different when reving the engine.....?
Im guessing the reason the auto box isnt functioning correctly is related to the fact the speedo fails.
Re: Major faults
« Reply #4 on: 15 March 2010, 12:50:24 »
Get your hands on a cheap multi-meter and read this http://www.omegaowners.com/forum/YaBB.pl?num=1225724099
Omega`s do funny things when the alternator is playing up :)
« Last Edit: 15 March 2010, 12:51:18 by RobG »
serek
  • huntingdon
    • 3.2 mv6
Re: Major faults
« Reply #5 on: 15 March 2010, 13:14:38 »
where about in cambs you are??
sound  Alternator like Rob say
cambs_nige
Re: Major faults
« Reply #6 on: 15 March 2010, 13:17:31 »
Hi Serek, im in Bassingbourn which is just down the road from Royston. Got to pick the kids up from school at 3pm so will venture into town for a multimeter
Re: Major faults
« Reply #7 on: 15 March 2010, 19:44:45 »
It may be as simple as a dodgy earth but my money is on the voltage regulator in the alternator :y :y
MutantCav
  • Gainsborough
Re: Major faults
« Reply #8 on: 15 March 2010, 19:52:17 »
Very similar to when my alternator bushes snapped and needed replacing apart from mine was manual so dont know if the box failed...it will as said be the bushes or regulator in the alternator...can easily just replace those bits and reuse your existing alternator :y
