Author Topic: alternator removal 2.2  (Read 922 times)
cambs_nige
« on: 16 March 2010, 12:02:23 »
Can someone please point me in the right direction for removing the alternator on the 2.2 engine starting with slackening the aux belt. Theres loads on the v6 but nothing on the 2.2.
Welung666
Re: alternator removal 2.2
« Reply #1 on: 16 March 2010, 12:05:31 »
It's a similar setup with the tensioner to get the belt off. Then a plug at the back and the bolts. Very easy on the 4 pots :y
« Last Edit: 16 March 2010, 12:05:47 by Welung666 »
cambs_nige
« Reply #2 on: 16 March 2010, 12:18:54 »
getting the belt off seems to be the biggest problem, I have loosened the centre bolt on the tensioner and the top left bolt on the frame but it wont budge
« Last Edit: 16 March 2010, 12:20:39 by cambs_nige »
« Reply #3 on: 16 March 2010, 12:40:20 »
You don`t loosen the bolt. 15mm spanner on it, turn clockwise as though you`re tightening it and the tension will release
cambs_nige
« Reply #4 on: 16 March 2010, 14:41:12 »
Job done, cheers for the advice. Now lets see if all my problems stop!
