Author Topic: manegment light stays on  (Read 821 times)
andy_driver
  • coatbridge
  • my omega had 7 of them + my 74 mini clubman estate
    • my omega of course
    • http://i746.photobucket.com/albums/xx101/andymoto29/omegapic1.jpg
« on: 17 March 2010, 11:36:16 »
hi i have replaced the intake air temerture sensor but the ecu light stays on . its says low voltage signal . reason why i think the light came on is a changed the radiator one day .but i took out the all  the bits and bobs were the air flow go,s so that wiring in that area i disconnected it but i think i have poss. strecth a wire or broken one cause the light does not go out after trying to reset it .
any help would be greatfull.
thanks
koni adjustable shocks eibach 30mm progrssive rate springs goodridge braided brakeline kit ebc redstuff ceramic brake pads all round black diamond drilled dics at front k+n panel filter  steinmetz body kit
Welung666
Re: manegment light stays on
« Reply #1 on: 17 March 2010, 11:53:08 »
How are you resetting it Andy?
« Reply #2 on: 17 March 2010, 12:25:12 »
Check you have not mixed up the connectors for the front multiram and the air temp sensor......the multiram one should be the longest lead.
