Author Topic: Door membrane  (Read 1351 times)
cmeonthemove
  • Taverham, Norwich
Door membrane
« on: 16 March 2010, 19:48:12 »
How much roughly is a door membrane? (Driver's door). I went to replace the lock at the weekend and found the membrane has been tampered with before and superglued to the door  >:( so simply peeling it off is a no-go. I should've got the hint to leave the door alone when I found the door pull handle was glued on as well.
Chris
2.5 Elite
Re: Door membrane
« Reply #1 on: 16 March 2010, 19:55:35 »
You cant get a pre-cut membrane they only sell sheet.....and given the vx pice of it I woul just source some suitable plastic sheet!
unlucky mark mv6
  • tipton,west mids
Re: Door membrane
« Reply #2 on: 16 March 2010, 21:34:54 »
Yep as mark said,just use some polythene as i did before with double sided tape,job done. :y
andyc
  • Norfolk
Re: Door membrane
« Reply #3 on: 17 March 2010, 08:49:01 »
Can do proper vapour shield at £2.72 per meter + VAT
Part number 93182394
Cheers
Andy
Thetford. Norfolk
cmeonthemove
  • Taverham, Norwich
Re: Door membrane
« Reply #4 on: 18 March 2010, 12:26:00 »
Cheers chaps. Best get some sheet then have another go.  :y
Chris
2.5 Elite
