Author Topic: fault codes??  (Read 1429 times)
familymad666
  • long sutton,lincolnshire
fault codes??
« on: 17 March 2010, 15:08:22 »
Hi everybody my name is Lee and i am new to this forum.I have a 2.6 v6 cd manual omega 2001.I brought the car with a oil cooler problem which i have replaced, before i put it on the road I have done a pedal test to get fault codes and have 0150,0120,0220 can anybody tell me what these mean thank you in advance.
Re: fault codes??
« Reply #1 on: 17 March 2010, 15:13:21 »
0150 - O2 Sensor Circuit (Bank 2 Sensor 1)
0120 - Throttle/pedalPosition sensor/switch A
0220 - Throttle/pedalPosition sensor/switch B
Is it all connected up correctly and running ok?
Will it rev?
familymad666
Re: fault codes??
« Reply #2 on: 17 March 2010, 15:24:09 »
Hi mark,the car runs and revs the way it should it idles at 550rpm and always sits there no fluxing up or down.if i rev the car it is quite responsive the only thing i will say is that when it idles there is a slight poping noise out the exhaust thanks mark.
familymad666
Re: fault codes??
« Reply #3 on: 18 March 2010, 15:13:28 »
If everything is working can anybody tell me what do do next i am a bit stumped.
Re: fault codes??
« Reply #4 on: 18 March 2010, 15:18:36 »
Is the EML light on ... (car with a spanner through the roof) ?? If not these might be "stored" codes that are not actually active. "Active" codes put the EML light on.
Stick your location in your profile .. there might be someone near you with the kit to reset the codes, you can then monitor and see if they reoccur.
HTH
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: fault codes??
« Reply #5 on: 18 March 2010, 15:27:03 »
what do you call the orange fault light which shows as an engine block? Emmissions light only I suppose.
Re: fault codes??
« Reply #6 on: 18 March 2010, 15:29:13 »
yup ... page 12 .. :)
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
familymad666
Re: fault codes??
« Reply #7 on: 18 March 2010, 15:39:08 »
eml is not on, location now posted.It still has slight poping from exhaust on idle and when it is being reved.Thanks for help..
Re: fault codes??
« Reply #8 on: 18 March 2010, 16:12:58 »
I wouldn't worry too much then ... if someone pops up living near you it might be worth getting the codes reset, you can then see if they recur.
Lets face it .. if the forum didn't tell you how to check the codes .. you wouldn't know they were there until the EML came on !!
