Author Topic: Central Locking - Problem !  (Read 2005 times)
Richard A
  • Aldridge, West Midlands
« on: 20 March 2010, 21:34:46 »
Having to'reprograme' the key, 6 times this week, having to use the 'key', central locking keeps 'dropping out', new battery fitted to key fob, any ideas ?
regards
richard a
richard a
Welung666
Re: Central Locking - Problem !
« Reply #1 on: 20 March 2010, 21:45:45 »
Check the battery holder isn't loose, they can break a solder joint which can inanvertantly disconnect the battery whilst rattling around your pocket. If not then I can stick your car on the "My Naff Code Reader" to see if there's a problem :y
Richard A
« Reply #2 on: 20 March 2010, 22:11:30 »
Cheers, sending 'spare' key to Martin Imber for a rebuild, may also take you up on your offer.
regards
richard a
richard a
falconsirrus
  • harlow, essex
« Reply #3 on: 20 March 2010, 23:00:07 »
hi guys new to the omega,
but do work with ford transits
like you said connection to the battery is main fault of any keyfob
no help info: the transits have a 2nd battery that work the c/locking, if all parts of keyfob are fine some times its that.
if all is ok with the keyfob could be a lose connection on the car
depends on the circumstances that its not working.
anyway hope you fine the answer
Page created in 0.228 seconds with 16 queries.
