Author Topic: 2.5 td fault code help req.  (Read 1481 times)
BRIGSPORT
  • Sunny Lancashire
« on: 20 March 2010, 22:05:28 »
Having done the paperclip test on my 96 2.5 td this evening it gave me a 64,91 and 92. The car takes a few turns to start whether hot or cold, so i am going to inspect and clean the fuel pump and swirl pot tomorrow, and hope this clears the 64. As for the cruise control, i was going to replace the stalk, and go from there.
Any ideas?
Re: 2.5 td fault code help req.
« Reply #1 on: 20 March 2010, 22:07:01 »
64 - tin of diesel magic in the fuel filter, see if that helps
Welung666
« Reply #2 on: 20 March 2010, 22:08:19 »
Agree, 91 and 92 are cruise related so I'm guessing you don't have cruise control or your stalk is breaked.
EDIT: Where are you matey?
« Last Edit: 20 March 2010, 22:09:28 by Welung666 »
BRIGSPORT
  • Sunny Lancashire
« Reply #3 on: 20 March 2010, 22:15:01 »
Thanks for the replies. The car has a cruise control stalk, so i am hoping a replacement will sort it, as it will come in handy when towing my mk1 escort on the motorway.. I am going to give the car a thorough going over and service so will try diesel magic when i change the fuel filter, but i am going to strip the pump down anyway.
BRIGSPORT
  • Sunny Lancashire
« Reply #4 on: 20 March 2010, 22:17:37 »
And i'm in lancashire at the end of the m65 (colne)
Also, once the car is fully serviced and tip top i will req. a chip for it so would be grateful if theboy can put me in touch with the chip man.
« Reply #5 on: 20 March 2010, 22:44:53 »
If it`s an auto you`ll need to upgrade the box to an AR35 if you`re gonna chip it
BRIGSPORT
  • Sunny Lancashire
« Reply #6 on: 21 March 2010, 00:10:06 »
The car is manual. I believe the rain has fooked off now, so i will be doing some serious investigation/servicing in the morning. Fuel pump is top of the list.
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #7 on: 21 March 2010, 01:26:27 »
Before you do your fuel pump, get a couple of replacement jubilee clips ready...  When I did mine, I had those stupid clips that clip onto themselves and a pain to reclip...
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #8 on: 21 March 2010, 10:49:10 »
Any ideas?
Here you go mate:
http://www.omegaowners.com/forum/YaBB.pl?num=1251298222
