Author Topic: windows problem  (Read 1551 times)
vbelen4
windows problem
« on: 21 March 2010, 18:16:25 »
One of the rear windows only moves 2 inches, up or down,  when you press the button, then it stops. It behaves the same with the drivers button or the rear seat button. Can anyone help to locate the problem?
Re: windows problem
« Reply #1 on: 21 March 2010, 18:18:15 »
Physically stuck in the runners?  :-/
Dany
  • Belgium
Re: windows problem
« Reply #2 on: 21 March 2010, 18:20:39 »
Unmount the door panel and maybe you'll see clearer
vbelen4
Re: windows problem
« Reply #3 on: 21 March 2010, 18:24:26 »
The window is not stuck, it can be moved to the bottom or to the top, but only two inches every time you press the button.
Dany
  • Belgium
Re: windows problem
« Reply #4 on: 21 March 2010, 18:27:38 »
Even if you keep your finger on the button?
Re: windows problem
« Reply #5 on: 21 March 2010, 18:28:25 »
there are sensors on the window motor to prevent the window closing on a child's head/etc. Your symptoms sound exactly like a sticking window, ie the sensors think there's an obstruction & cut power. Try spraying a silicon lub in the runners.
vbelen4
Re: windows problem
« Reply #6 on: 21 March 2010, 18:33:24 »
Yes, it stops like if it were an obstacle in its way. I'll lubricate the runners.
Thanks.
Page created in 0.013 seconds with 14 queries.
