Author Topic: Rattling Door Pins Quick Fix  (Read 2722 times)
RichardH
  • Ireland
« on: 10 November 2009, 10:06:49 »
Having listened to my door lock pins rattling for the last few months I decided to try and quieten them down before they drove me crazy.
I hope this quick fix can help anyone else out there with the same problem and it only takes about five minutes.
The first step is to lever out the red tab on the locking pin.  I used a small precision screwdriver to do this.  The red tab does not have to be removed completely.
To remove the pin just pull straight up.
Wrap a piece of insulating tape around the base about two or three times and trim the excess from the bottom.
Replace the pin and push the red tab back in.  Repeat the procedure for all four lock pins and that should be it.
Harison213
Re: Rattling Door Pins Quick Fix
« Reply #1 on: 10 November 2009, 10:40:34 »
Thanks for that Richard. Last time I did it I took the door cards off although I was replacing the speakers at the same time. I completely understand how this little thing can drive you crazy. The other way of getting rid of this is by turning up the volume on your stereo  ::)
TaxiManDan
  • Cheltenham
« Reply #2 on: 10 November 2009, 12:33:28 »
hey thanks for this, it has been driving me mad since i got the car  8-)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #3 on: 10 November 2009, 18:21:20 »
This is one for the 'how to' section if I ever saw one.... :y
My drivers side one is making me go mad!
Nice one!  :y :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
MickAP
  • South Derbyshire
« Reply #4 on: 10 November 2009, 18:24:37 »
Nice one!  :y :y
Yep just the drivers side rattles on mine.
Nice one will try the fix.
Mick
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #5 on: 15 November 2009, 17:06:01 »
Actually stopped raining for 5 mins earlier, so was able to do this on mine - three layers of tape was too much, two was just right - worked a treat  :) Cheers!  :y :y
sara1983
« Reply #6 on: 15 November 2009, 20:42:20 »
must do this on both of mine,as its like Chinese torture listening to then rattle.
  • Auckland
    • Mazda MPV
« Reply #7 on: 15 November 2009, 20:50:04 »
Did mine this afternoon :y
Got a 250 mile drive on Wednesday morning so will find out if it was successful.
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #8 on: 18 March 2010, 23:03:38 »
 ;)Does any one know how to stop the pins on a mini facelift rattling as I am guessing this fix is for a facelift as my pins look differant ?
2001 MV6 3.2 manual been converted from 2.6 auto
« Reply #9 on: 19 March 2010, 08:05:53 »
Thought at factory they had a small bit of felt glued in channel to stop the rattle?
RichardH
  • Ireland
« Reply #10 on: 19 March 2010, 11:32:20 »
If I am remembering correctly, my pre-facelift had this strip of felt, but the none of the 3 facelift’s I have had since then had any.  I have had the rattling pins on all three facelifts.
bigtow
  • rochester kent
« Reply #11 on: 22 March 2010, 11:21:47 »
whats the main cause of rattles on a pre facelift then ?
