Author Topic: I have a Vauxhall Omega 2.0 P-Plate  (Read 1685 times)
OGCDaz
  • ashford kent
« on: 23 March 2010, 15:03:24 »
I have had my eml read and in came up with this code P0335
How can i fix this Problem and what is the problem
« Last Edit: 23 March 2010, 15:03:55 by OGCDaz »
OGCDaz
  • ashford kent
Re: I have a Vauxhall Omega 2.0 P-Plate
« Reply #1 on: 23 March 2010, 15:45:45 »
anyone out help me plz
Welung666
« Reply #2 on: 23 March 2010, 16:00:53 »
Cam sensor needs changing. Use genuine Vx sensor and an easy change. Where are you Daz?
cleggy
« Reply #3 on: 23 March 2010, 16:02:28 »
I am sure that somewhere on here there is a list of the codes, but I'll be buggered if I can find it. I might have a hard copy in the car, hang on a min while I look.
I am also sure these are very common, and someone will be along with a full explanation.
Just had a look CAM SENSOR.
cleggy
« Reply #4 on: 23 March 2010, 16:03:46 »
Welung666 well done.
Note to self must type quicker ;D
OGCDaz
  • ashford kent
« Reply #5 on: 23 March 2010, 16:05:12 »
im sure its the Crankshaft Position Sensor but havent a clue where it is on the car lol
« Reply #6 on: 23 March 2010, 16:23:21 »
This link is for the 2.2 .. but I think the 2.0 is similar ??
(both missing 2 pots but never mind ..)  :)
http://www.omegaowners.com/forum/YaBB.pl?num=1269023974
Welung666
« Reply #7 on: 23 March 2010, 16:35:21 »
Normally the cam sensor on the 4 pots but your P0335 has disproved that.
« Last Edit: 23 March 2010, 16:37:20 by Welung666 »
« Reply #8 on: 23 March 2010, 16:35:26 »
Correct. Crank sensor. Read this for fitting http://www.omegaowners.com/forum/YaBB.pl?num=1187777000/0 :y
« Reply #9 on: 23 March 2010, 16:35:59 »
Normally the cam sensor on the 4 pots and your P0335 has proved that.
Crank sensor Lee
Abiton
Welung666
« Reply #11 on: 23 March 2010, 16:38:10 »
Crank sensor Lee
I know, just modified my post. I'm working from memory here ;D
« Reply #12 on: 23 March 2010, 16:39:01 »
Crank sensor Lee
:P
« Reply #13 on: 23 March 2010, 16:47:37 »
ignore my post as I believed welung666  .....  stupid of me I know .....
 ;D ;D ;D ;D ;D ;D ;D
« Reply #14 on: 23 March 2010, 16:51:16 »
It was relevant to Lee`s initial unedited answer :)
