Author Topic: Headlight washers  (Read 1044 times)
downsmen
  • Kent
    • 2.5 V6 Elite Estate
Headlight washers
« on: 24 March 2010, 13:07:04 »
my headlight washers dont work
1. when should they work? i have tried them woth lights on and off. No difference
2. Where should i start to look to get them working again?
3. Is it a MOT failure?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Headlight washers
« Reply #1 on: 24 March 2010, 13:35:01 »
the washers should only work with headlamps on,they are not tested for mot.when you lift the bonnet the pumps for both windscreen and headlamp wash are behind the bumper
other rides
« Reply #2 on: 24 March 2010, 14:21:04 »
2. Where should i start to look to get them working again? .....
The relay for them is in the triangular relay/fuse box under the bonnet. IIRC the 2nd relay from the front has a fuse carrier next to it, these are for the washers. Check the fuse is still there (mine's in my door bin) & that it's not blown.  :y
downsmen
  • Kent
« Reply #3 on: 24 March 2010, 15:05:57 »
Thanks for your help will have a look there later
