Author Topic: Problem with neutral RPM  (Read 794 times)
Rafal
« on: 25 March 2010, 23:32:00 »
Hello!
I need a help with my omega (1994 x20xev, automatic). On neutral gear when engine is warm the rpm are waving between 1400-1800 all the time. I've read the blinking code and the result is 21, 34, 47 and 71. Then I clean the throttle and changed the throttle position sensor for a different one (not new but should be good). And then the results are 21, 34 and 73. I have to say, that before the rpm problem I've had only one problem - 34, but it doesn't affect how the engine works so I just get used to the lighting check light :)
Please help. All advise will be appreciate.
