Author Topic: help got 0334 code  (Read 2887 times)
idc62
  • Llanharry south wales
    • x reg 2ltr gls and 03 2.6
help got 0334 code
« on: 23 March 2010, 19:12:16 »
car started fine this morning but stalled pulling out of drive turned engine over 3/4 times strarted but eml on left it at home.what is0334 which igot with paperclip test in thanks in anticipation of help 2.0 16v auto 98
Re: help got 0334 code
« Reply #1 on: 23 March 2010, 19:17:09 »
I can't find any reference to 0334 mate, are you sure you read the code properly? 0335 would be a problem with the crank sensor, 0340 is the cam sensor HTH :-?
« Reply #2 on: 23 March 2010, 19:18:24 »
Are you certain of the code ???
this page, 2.0 - Simtec 56 2.0l Fault Codes,  doesn't list a 0334
http://www.omegaowners.com/forum/YaBB.pl?num=1206569945
but an 0335 would explain the symptoms.
this page, 2.0 - Simtec 56.0/56.1 2.0l 16V Fault Codes, gives 2 digit codes
http://www.omegaowners.com/forum/YaBB.pl?num=1207565476
idc62
« Reply #3 on: 23 March 2010, 19:19:24 »
will redo clip test back in a mo
idc62
« Reply #4 on: 23 March 2010, 19:26:45 »
oops 0335 its been a long day
« Reply #5 on: 23 March 2010, 19:29:35 »
P0335      Incorrect RPM Signal
Camsensor I believe ..  :)
This is for the 2.2 .. but I believe the 2.0 is similar .. :)
http://www.omegaowners.com/forum/YaBB.pl?num=1269023974
idc62
« Reply #6 on: 23 March 2010, 19:46:20 »
thats at the front/top of cylinder head under black cover isn't it??
« Reply #7 on: 23 March 2010, 19:51:50 »
Yes mate, that's it. :y Have a look in the Maintenance Section, it's the first howto you come to ;)
« Last Edit: 23 March 2010, 19:56:30 by philrich1064 »
idc62
« Reply #8 on: 23 March 2010, 20:05:53 »
thanks philrich is this best to be bought from vauxhall or is there another supplier
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #9 on: 23 March 2010, 20:09:41 »
Be warned - I seem to remember that this item has been upgraded and there is a modification to the wiring......
It's just something lying far back in the grey matter, so it may be a load of rubbish!
best wishes
Simon.
idc62
« Reply #10 on: 23 March 2010, 20:18:36 »
i had a 2.0 cav ecotec and a mod was done to wireing to stop it " spiking out " and affecting cam sensor by a local vauxhall place but they arn't there any more
« Reply #11 on: 23 March 2010, 22:40:00 »
Been here before Nige http://www.omegaowners.com/forum/YaBB.pl?num=1269356604  Crank sensor
« Reply #12 on: 23 March 2010, 22:46:16 »
Sod it .. I'm going to stop trying to help on the 2/3 size engine ... :(
if they ain't got the right number of cylinders ....  :-/ :-/ :-/ :-/
« Reply #13 on: 23 March 2010, 22:48:28 »
;D ;D ;D ;D ;D
idc62
Re: help got 0335 code
« Reply #14 on: 25 March 2010, 20:54:47 »
changed sensor still same problem hard to start idle slightly higher slight miss now and then and same bloody 0335 code not my day is it hope someone can help thanks ian :-? :-?
« Last Edit: 25 March 2010, 21:14:25 by idc62 »
