Author Topic: irmscher sportstar 9j alloys  (Read 1698 times)
SteveT528
« on: 25 March 2010, 23:49:15 »
i have a set of these will fitting 9j alloys on the front of my omega be ok? they seem to fit and dont rub but been told not to use them on the front?
tyres are: 265/35/18
« Last Edit: 25 March 2010, 23:49:44 by SteveT528 »
2woody
  • Northumberland
Re: irmscher sportstar 9j alloys
« Reply #1 on: 26 March 2010, 08:18:54 »
the tyre size is reasonable diameter-wise ( 1.5% out )
but I think that the width might cause you a problem at the front.
Try bolting one up and going lock-to-lock ( with weight back on the wheels ). It'll be obvious if the diameter is too big as it'll catch the strut spring pan.
to drive, the tyres will wreck the handling - don't forget that handling is almost the opposite of grip - when you increase grip, handling will get worse. Expect tram-lining, too.
it's a matter of preference, but I reckon that 225 is probably a little too wide for decent handling.
serek
  • huntingdon
    • 3.2 mv6
« Reply #2 on: 26 March 2010, 09:37:27 »
I got 255/35/18 on front, 8J wheel and that is limit IHMO , best size for front is 245/35 or 235/40 for safe driving
« Reply #3 on: 26 March 2010, 09:58:24 »
that size it tight enough, and conti sc3 aint cheep in that size are they...Jeee  sus!   :o
« Last Edit: 26 March 2010, 10:01:13 by chrisgixer »
2woody
  • Northumberland
« Reply #4 on: 26 March 2010, 11:15:50 »
if it's any help, I'm looking for two 9-inch rims at the moment
SteveT528
« Reply #5 on: 26 March 2010, 19:18:41 »
2woody, do you have 2x 8j rims for a swap maybe ?  :)
thanks for the replys everyone.
Dany
  • Belgium
« Reply #6 on: 26 March 2010, 19:43:10 »
That's what I'm looking for too :D
SteveT528
« Reply #7 on: 26 March 2010, 21:02:58 »
dany, are you after 8j's aswell or 9j's?  :)
Dany
  • Belgium
« Reply #8 on: 26 March 2010, 23:59:58 »
Like explained here http://www.omegaowners.com/forum/YaBB.pl?num=1269514389
I have a set of four 9"... and I'm after two 8", and then I'll sell two 9"  :)
I can't do a swap because I live in Belgium... So I want to buy 8" and then sell 9".
« Last Edit: 27 March 2010, 00:00:46 by moudufond »
2woody
  • Northumberland
« Reply #9 on: 27 March 2010, 13:59:17 »
I have none - but I'm trying to find some ....!
actually, I could use 4
Dany
  • Belgium
« Reply #10 on: 27 March 2010, 17:18:07 »
Tell me if you find, and I'll reserve the pair of 9" for you ;)
