Author Topic: lamba or cat failure (update)  (Read 954 times)
mantagte
  • great yarmouth
    • omega bmw maverick
« on: 20 March 2010, 12:39:22 »
replaced the lambda sensor with a new one from vauxhall
car was back in for retest this morning
result FAILED >:(
fast idle
co was 0.53 now 0.61
lambda was 1.050  now 1.038
hc was 20 now  88
second fast idle
co was 0.57  now 0.73
hc was 1 now 101
natural idle test
co was 0.36  now 0.49
guess its the cat then
lambda was 1.049   now 1.035
Re: lamba or cat failure (update)
« Reply #1 on: 20 March 2010, 17:14:07 »
mate, I think trial error will be an expensive way  :-/
as  I mentioned before I still think you have problem with ignition and/or combustion in some cylinders are not complete.. and also  a compression test may give better ideas imo.. :-/
mantagte
  • great yarmouth
« Reply #2 on: 20 March 2010, 19:00:23 »
thanks Cem
will check the compressions in the morning
the car has had new plugs leads coil pack
a replacement maf as there was a code p0100 relating to that put replacement maf on cleared code
no codes have returned
« Reply #3 on: 20 March 2010, 19:27:09 »
if those tests dont give a clue including the compression test , check coolant temperature sensor.. and ideas finished :P
rhinofender
« Reply #4 on: 27 March 2010, 17:23:41 »
We had the same problem with our mercedes, it was the air mass sensor
