Author Topic: Re: Possible gasket??  (Read 1131 times)
« on: 27 March 2010, 22:32:40 »
Had a look at a great car today and when looking in the oil filler cap it had alot of mayo in it and down the tube is it a gasket or something else?or could it be blockage?no sign of anything in the header tank just clean water with antifreeze and radseal.any suggestions? :y
That would be a concern to me... It's dreadful stuff for the cooling system :(
Need a bit more info about the car before we can give a better answer though... If a V6 it's probably normal and only been doing short journeys... Regular oil changes with quality (GM) oil will reduce this :y :y
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« Reply #1 on: 27 March 2010, 22:34:24 »
It seemed down on power too till around 3000 revs but once hitting that was ok didn't take it on a long drive today just couple of miles
scream if you want to go faster!!!
« Reply #2 on: 27 March 2010, 22:36:46 »
What car?
mr ICE man
  • dolgellau wales
« Reply #3 on: 27 March 2010, 22:39:38 »
Good point!on 2.5 v6 less then 100000 miles has been looked after to my knowledge
« Reply #4 on: 27 March 2010, 22:54:01 »
It's probably just condensation... But I'd exorcise caution because of the radweld :-/ :-/
« Reply #5 on: 27 March 2010, 23:26:05 »
Demons in the cooling system  :question ::) :o :D ;D ;D
« Reply #6 on: 28 March 2010, 14:10:57 »
usually caused by front multi ram vacume failure shold not be too hard to sort out, who did the cam belt and when was it done last? should say in the history.
