Author Topic: Tractor Owners!  (Read 2277 times)
MickAP
  • South Derbyshire
Tractor Owners!
« on: 28 March 2010, 19:35:28 »
Been getting down and dirty with the TD estate today.
Whilst I was in the mood after sorting out my rear brakes (the pads were seized in the calipers) I though I'd give it a bit of TLC under the bonnet.
Removed the air charge pipe and gave it a good clean with engine degreaser. Also noticed when inspecting the leak off pipes (they were dry, so no leaks there) that the inlet manifold around the flanges appeared to have a small amount of oil around them. So I just nipped them up, maybe they were leaking slightly.
Question is  it worthwhile removing the part circled in the picture below, and second larger picture, to give it a clean inside? Do I need a gasket when refitting?
Anyway cleaned up the whole front area as that little oil blow hole drips oil over the alternator and general area. Going make a patch also to go over the top rad hose, because oil drips on that from said hole and it's going soft.
Anyway just oil and filter change next, also air and pollen filter (that really looks the pits) to change and we should be all done.
That is apart from some new clips/pins putting on the rear calipers to hold the pads in :y
Mick ;)
Re: Tractor Owners!
« Reply #1 on: 28 March 2010, 19:42:10 »
I've done away with my EGR valve and the pipe to it and i'm also getting rid of the plastice bit with Turbo Diesel written on it as it tends to leak from the seams ;)
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
Re: Tractor Owners!
« Reply #2 on: 28 March 2010, 19:42:25 »
I haven't removed the EGR assembly ( I think), but, I have removed a blanked the egr pipe, which does give slight performance improvement...  The only reason was purely due to the pipe fracturing...
charlie
  • sunderland
Re: Tractor Owners!
« Reply #3 on: 28 March 2010, 19:43:09 »
well that a nice clean engine there :yif the egr valve looks dirty i would take it off and clean it,its reconmend on here to use paint stripper(sounds abit harsh ) :y
Re: Tractor Owners!
« Reply #4 on: 28 March 2010, 19:46:54 »
If you think the EGR valve is dirty just wait till you see the inlet manifold ;D
MickAP
  • South Derbyshire
Re: Tractor Owners!
« Reply #5 on: 28 March 2010, 20:09:58 »
Yes I like to keep it clean, another pic after a clean up.
As for paint stripper :o
What about just a spray degreaser?  :y
Mick ;)
Re: Tractor Owners!
« Reply #6 on: 28 March 2010, 20:15:09 »
I used Nitromors on my inlet manifold and it works a treat ;)
charlie
  • sunderland
Re: Tractor Owners!
« Reply #7 on: 28 March 2010, 20:20:24 »
Yours look pretty clean inside so use what you feel comfortable with :y :y :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Tractor Owners!
« Reply #8 on: 28 March 2010, 20:27:53 »
It won't do any harm to give the EGR valve a clean out Mick.
If the hose that connects the charge-air pipe to it is in sound condition, that oil drip is probably coming from the breather hole at the base of the valve.
Some EGR valves have two small-bore pipe outlets, and some have only one - which is connected to the boost valve.
I'm lucky as mine is the two-pipe version, so there's now small-bore tubing from it leading down to the road, and no more oil blowing over the top hose.
I use Gunk to clean-out the EGR and charge-air pipe.
MickAP
  • South Derbyshire
Re: Tractor Owners!
« Reply #9 on: 28 March 2010, 20:36:02 »
Mines got a pipe coming from it, guess to the boost valve. Also a breather hole. So did you stick the pipe in there to drain away the oil?
The hose to charge air pipe is ok, leak free :y
Mick
Seth
Re: Tractor Owners!
« Reply #10 on: 28 March 2010, 21:06:04 »
Mick
No, there was already a metal pipe fitted there.
I just sleeved some small-bore rubber tubing onto it, and clipped this tubing downwards well below the engine. That way, any oil drips onto the road, and not over my clean engine bay!
Ideally, you need to source a two-pipe EGR valve, to replace your present 'one pipe - one breather hole' jobbie.
MickAP
  • South Derbyshire
Re: Tractor Owners!
« Reply #11 on: 28 March 2010, 21:54:52 »
Or take it off and try and stick a pipe in there :y
Mick ;)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Tractor Owners!
« Reply #12 on: 29 March 2010, 01:58:00 »
Start with a large spade :y  ;D
