Author Topic: Rear view mirror  (Read 1038 times)
des
  • stoke-on-trent
Rear view mirror
« on: 29 March 2010, 20:30:27 »
Wot do u do to fix one of these, mine is soooo loose it just flop's a round  :'(
Only just got the car, didnt see the prob till after i got home- bugger.
Re: Rear view mirror
« Reply #1 on: 29 March 2010, 20:35:19 »
Is the mounting point on the screen secure? Mirrors just slide onto its mount. Remove it (grab each side of the mirror & slide down) & check inside where it slides onto the screen, there's sprung clips inside IIRC.
Welung666
« Reply #2 on: 29 March 2010, 20:36:16 »
Des where are you? Seems you need a day at either mine or DLK's to sort all these little niggles out ;D
Abiton
« Reply #3 on: 29 March 2010, 20:38:43 »
If it's the same as the one on our poverty-spec 96 car, you'll find that the socket bit of the plastic balljoint that the mirror pivots on is cracked.
Small tyrap done up v. tight around it may help.
« Reply #4 on: 29 March 2010, 20:42:35 »
Ah! You're probably right, I forgot that not all mirrors are like mine.
My Astra's used to be loose on the ball too. SWMBO's Astra had a mirror that stayed put ...... funny how easy things get swapped from a car that's been written off.  ::)  ::) :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #5 on: 29 March 2010, 21:08:56 »
 ::) Sounds like a ball joint, perhaps it is time to upgrade to an auto dimming one?  ::)
« Last Edit: 29 March 2010, 21:09:38 by Agemo »
