Author Topic: Brake caliper question  (Read 3524 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 31 March 2010, 12:46:32 »
Is there some magic trick to get the caliper piston back?  I know on audis there is a thread you have to screw it back onto.
I am currently in the process of changing the front discs nd the caliper wont budge!  Is it caliper off and in the vice time?
Re: Brake caliper question
« Reply #1 on: 31 March 2010, 12:49:47 »
I use a LARGE pair of plumbing pliers, there is a "flat" on the back of the caliper, and the pliers fit there nicely, other jaw goes right across both sides of the piston to keep it flat ... firm squeeze and the piston slides in nicely .. :)
« Reply #2 on: 31 March 2010, 12:51:25 »
Flat bar against the old pad works for me. Have you tried loosening bleed nipple slightly
« Reply #3 on: 31 March 2010, 13:07:59 »
Open the bleed nipple and squeeze the piston in.
No special trick......
« Reply #4 on: 31 March 2010, 13:09:50 »
Loosen bleed nipple - fit tube onto nipple, other end into jar with fluid in (as if bleeding).
Piston should push back easily (use large pliers or g-clamp + wood).
Gaffers
« Reply #5 on: 31 March 2010, 13:25:26 »
sorted, used a frame box vice ratchet thing :y
cannonfodder
  • Leicester
  • Never ever Blimin anything ever
« Reply #6 on: 31 March 2010, 20:27:57 »
Just did mine literally ten minutes ago... great fun putting my wheel back on in the dark...   I used a piece of 5" X 1" Hardwood placed over the piston, and levered against that, worked a treat for me.
pembsomega
  • pembrokeshire, wales
« Reply #7 on: 01 April 2010, 11:00:51 »
http://cgi.ebay.co.uk/New-Draper-Brake-Caliper-Piston-Retraction-Tool-1-2_W0QQitemZ150427845311QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item230632c2bf
buy one of those best tenner i ever spent (at local factors not ebay price)
works like a dream and you know your pushing the piston in nice and square as not to damage the seals
« Reply #8 on: 01 April 2010, 11:14:32 »
they are a handy tool for general work, but really should not be needed on this car. If its that much trouble to push back in on the Omega theres sumat wrong ime.
pembsomega
« Reply #9 on: 01 April 2010, 11:20:09 »
ah ok, i didnt mean justfor omegas, theres one in my toolbox and i use it on everything and i like tools that are simple,do the job and work everytime ;)
« Reply #10 on: 01 April 2010, 13:45:00 »
A word of caution.
IF you force brake pistons in without opening the bleed nipple, you run the risk of inverting the master cylidner seals and amybe getting air into the ABS modulator.
If you open the bleed nipple....the force required is minimal!
markfree
« Reply #11 on: 01 April 2010, 14:03:30 »
I clamp the flexi brake hose, open the bleed nipple and just push the caliper piston in with a screwdriver - all the old brake fluid is then expelled :y
pembsomega
« Reply #12 on: 01 April 2010, 14:54:08 »
A word of caution.
goes without saying, the amount of people who must bugger their master cylinder......................
barclay03
  • Glasgow
« Reply #13 on: 01 April 2010, 15:39:43 »
Ive never loosened the bleed nipples on calipers whilst winding them back, and i do them pretty often. Usually whip the cap off the reservoir.
« Reply #14 on: 01 April 2010, 15:44:47 »
i use big pair of grips to push the caliper back in, needs a bit of effort (especially from me)  ::)
