Author Topic: 2001 mv6 misfire  (Read 1072 times)
squid
2001 mv6 misfire
« on: 02 April 2010, 11:37:54 »
hi my 2001 mv6 estate has a misfire on 2nd cylinder a mobile mechanic had promised to do it for me this week as i am supposed to be going away this weekend he was going to do the spark plugs to start with what id like to know is is the car ok to drive or will it cause more damage also is it a hard job to do im not mechanicly minded im just so annoyed as ive only had the car 3 weeks thanks for any replys.
Re: 2001 mv6 misfire
« Reply #1 on: 02 April 2010, 12:10:54 »
also is it a hard job to do im not mechanicly minded .....
Not really, have a look & see what you think.  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1169337137 A misfire could just be a spark plug, but could also be due to a failed coil pack. Have a look down the spark plug holes for signs of oil, cam cover gaskets fail & flood the plugs.  ;)
« Last Edit: 02 April 2010, 12:11:04 by Andy_B »
guncharmer
  • York
« Reply #2 on: 02 April 2010, 12:20:09 »
Have you got any service  history with this car or receipts for recent work and when is the cambelt due? This is relevant to work out the best way to resolve your problem e.g. have the plugs been changed per schedule?,camcover gaskets recently replaced?
guncharmer
  • York
« Reply #3 on: 02 April 2010, 16:04:12 »
From your pm, car has done 94k,cambelt 80k,loads of history but no mention of cam cover replacement or spark plug change. Have you checked plug wells visually as recommended  by Andy B? If you have decided to leave it to a mechanic then show him the guides on here.If the wells are contaminated then cleaning them might provide a very short term fix but you will need the camcover gaskets changed and the breathers cleaned a.s.a.p.,again show your man the guide on here. If they are uncontaminated then change the plugs as the cheapest start point and if that doesn`t sort it then you 99% need a new coil pack.
Lastly , did you do the `pedal trick` to identify your misfire on cylinder 2?. Regardless ,do it anyway(guide on here) and post up the codes showing. Oh and yes,driving with a misfire can damage the cat convertors.
Go to maintenance guides,click maintenance guide index and scroll away
« Last Edit: 02 April 2010, 17:44:07 by guncharmer »
