Author Topic: 3.0 running problems  (Read 1679 times)
omegasport
« on: 01 April 2010, 18:18:27 »
hello everyone im new to this site ive had my omega for 1 week . the second day i bought it it seems to be running very bad when on idle. i was wondering if anyone could help me its a 1998 mv6 3.0 auto saloon
thanks paul
Welung666
Re: 3.0 running problems
« Reply #1 on: 01 April 2010, 18:43:13 »
Where are you Paul?
« Reply #2 on: 01 April 2010, 18:45:04 »
first off clean the ICV, then check for any air-leaks  :)
omegasport
« Reply #3 on: 01 April 2010, 19:32:39 »
hello i live in totton hampshire
Welung666
« Reply #4 on: 01 April 2010, 19:58:05 »
Miles away ;D There goes me offering to help you :P ;)
omegasport
« Reply #5 on: 01 April 2010, 20:38:36 »
lol thanks for your offer mate .when i stated to play with my car . i removed aload of pipes just to see if any was blocked the problem is .i removed all i could see at 1 go and forgot where they all go .so i refitted them as i thought was best and seems to be no change in the running .would anyone have a diagram showing where the pipes are ment to go .
thanks paul
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #6 on: 01 April 2010, 21:57:09 »
Paul, there are loads of useful pics in the maintenance section. If it was the breather pipes etc that you removed check out that particular 'how to' for info  :y
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
« Reply #7 on: 02 April 2010, 09:31:58 »
I take digital photos to show where stuff goes before starting any job like this.
omegasport
« Reply #8 on: 02 April 2010, 22:27:55 »
hi i have checked all pipes i got a diagram from here thank you for that. and ive removed all of them checked them all and gave them an extra clean including the metal breather box. all refitted and made no difrence to the running ? do these miggys have any other common problems ?
« Reply #9 on: 02 April 2010, 22:32:09 »
As you've had bits on and off .. its possible you have a "vac leak" ... to check, with the engine idling, spray around lightly with carb cleaner... if the engine note suddenly changes the carb cleaner has been sucked in and burned as extra fuel !!!  You've just found the vac leak !!  Wipe down with paper towel and you also have a clean engine .. :)
