Author Topic: Rumble under bonnet.  (Read 885 times)
Mikes1670
  • Hull
« on: 03 April 2010, 08:38:27 »
Hi all, I have a 3.0 Elite (V-reg, 1999) and I have noticed that when I turn on the ignition, if I dont crank the engine there is a rumble under the bonnet.  It is more apparent if the engine isn't actually started up. It occurs when the ignition is turned on but not far enough to start cranking the engine. Has anyone else noticed this or is it just me?  The car is fairly new to me and I am still getting used to it.
MutantCav
  • Gainsborough
Re: Rumble under bonnet.
« Reply #1 on: 03 April 2010, 09:07:48 »
Sounds like the motor noise you get from the Secondary Air Injection Pump, nothing to worry about...its normal
