Author Topic: auto gearbox level checking  (Read 773 times)
abondance kid
« on: 03 April 2010, 09:15:19 »
hi, I want to check the level on the gearbox as I have a whinning noise
Re: auto gearbox level checking
« Reply #1 on: 03 April 2010, 09:20:59 »
low ATF would cause slipping, not really a whine, suggests torque converter   :-/
To check ATF, take drain plug out, have the engine running on a level surface, and go through the gears checking the level, it should be level with the fill plug
« Reply #2 on: 03 April 2010, 09:36:53 »
As tunnie says, on level surface, engine running, undo filler bolt.
As oil grows in volume as it is used, expect a fair amount to come out.  Should be at the level of the filler hole.
