Author Topic: Drivers heated seat inop  (Read 1607 times)
Justdave
  • Merseyside
« on: 03 April 2010, 09:30:33 »
I recently noticed that the heated seat on the drivers side on my 02 Elite has stopped working, can anyone help point me in the right direction as to where to start ! is it a common problem ! all the other seats work fine.
Cheers
Dave
Re: Drivers heated seat inop
« Reply #1 on: 03 April 2010, 09:33:52 »
Common, and unless you are an upholsterer, not worth effort fixing.
If its leather, the official fix is a replacement seat (heater sewn into leather to make in work more effectively, rather than under it as with the case of cloth seats)
Justdave
  • Merseyside
« Reply #2 on: 03 April 2010, 09:40:58 »
It's cloth, I was kinda hoping it was a common issue, an easy fix ! no such luck by the sounds of it.
« Reply #3 on: 03 April 2010, 09:45:08 »
Need to strip the seat and replace the heater pads.  You can try farting around checking fuses etc, but I bet its a failed pad.
If facelift, I think the pads are different(?) due a more intelligent thermostat.
Justdave
  • Merseyside
« Reply #4 on: 03 April 2010, 10:05:02 »
Cheers, is it one pad for base and backrest or two separate ones ? Base & backrest both u/s.
« Reply #5 on: 03 April 2010, 12:00:26 »
Two separate pads. Prefacelift are wired in series soif one dies you lose both. Not sure of wiring differences betweem the older & newer cars as the later have variable heat settings.  :y
I_want_an_Omega
« Reply #6 on: 03 April 2010, 12:15:14 »
Hold on guys. Elite cloth seats are built in the same way as leather ones and as such don't have pads.
Its only the lesser models, and also MV6 leather, that have the separate pads.
« Reply #7 on: 03 April 2010, 13:48:07 »
prolly explain why elite cloth, and non sports leather are the most unreliable then ;D
« Reply #8 on: 03 April 2010, 13:52:10 »
another good reason for CD spec, both of mine still work, and the Elite's one doesn't
I_want_an_Omega
« Reply #9 on: 03 April 2010, 13:57:46 »
I can only speak for pre/mini facelift models as they are the only ones that I've had apart.
The Elite seats have extra padding and have a long stranded element weaving back & forth inside the foam. The CD/CDX seats even with the same fabric (Dots IIRC) have less padding and separate elements.
