Author Topic: Are these geometry settings good enough?  (Read 4685 times)
Rob James
  • Sheffield
« on: 23 March 2010, 08:02:54 »
I have a 1999 3.0 MV6 which has done 90,000 miles. I have had a full geometry setup done, but I'm still not happy with it. The place I went to are not willing to make any charges without charging me a fortune as all values are within their tolerances. What do you think to these?
Cheers,
Rob.
« Last Edit: 23 March 2010, 08:03:37 by bobbyg »
Kaycee
  • Doncaster
Re: Are these geometry settings good enough?
« Reply #1 on: 23 March 2010, 08:10:48 »
camber on front left 1.4 right 2.0 this will make car pull to left needs to be 1.10 if any thing left side a bit more than right
i.e left -1.12 right -1.10 or there abouts
There is a tide in the affairs of man if taken at the flood will lead on to greater things
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #2 on: 23 March 2010, 08:23:26 »
Get yourself down to WIM, I know its a bit far from Sheffield but very worth it.  £60 + vat to OOFers, I'm booked in next week before I go around the country on me hols :y
« Reply #3 on: 23 March 2010, 08:27:34 »
Time to name and shame.....so other members can avoid like the plague.
From what I can see, they have attached an expensive bit of kit and only adjusted the front toe.
I take the view that yes, this kit is expensive and teh charge is more than a standard tracking setup asa result but, I expect the functions of the kit to be used correclty and learly hre you could of saved cash and just had the front toe set!
Front camber needs setting ....this will cause a pull to the left and will wear the inside edges of the tyres (OSF in particular).
Rear toe could be better.
Rob James
  • Sheffield
« Reply #4 on: 23 March 2010, 09:09:29 »
Well if others want to recieve the same level of service I recieved they can go to Challenger tyres in Sheffield. If you would like your car to be just right then try elsewhere.
Mark - was it Fleet Fit in Loughborough you said was good?
Cheers.
« Reply #5 on: 23 March 2010, 09:54:25 »
Cheers.
Yes, they take a lot of time and care over teh work, its owner run and they know the Omega settings
Fleet Fit (Loughborough)
Tel: 01509 272109
Unit C4,
Cumberland Trading Estate,
Cumberland Road,
Loughborough,
LE11 5DF
« Reply #6 on: 23 March 2010, 09:54:54 »
Cheers.
Dare I ask how much they charged?
Rob James
  • Sheffield
« Reply #7 on: 23 March 2010, 10:50:35 »
Cheers.
£42, and that was meant to include all corrections. However as everything was in the 'green' they wanted to charge that again for each aditional adjustment (and they said that making any further adjustments was a waste of time and would have no effect).
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #8 on: 23 March 2010, 12:20:32 »
How come WIM are the ONLY people in the whole of Britain that can be trusted with an Omega? Surely other places with any sort of reputation would know, or be able to learn, the geometry set-up? It can't be that hard, surely?
« Reply #9 on: 23 March 2010, 12:33:16 »
You want to try to get some of them to touch a kit car where they have no settings on their machine (but presented by an owner who knows exactly how he wants it set up)!
They invest a fortune in equipment and equip it with a gibbon that only knows green and red, and how to round off a track rod lock nut with a mole wrench.
jonnycool
« Reply #10 on: 23 March 2010, 12:38:17 »
Yes, you're right - I know of someone who went to have a tyre changed but didn't want the neanderthal doing it to overtighten the nuts, so when he asked him to torque the nuts properly, he did the nuts up with a windy gun then demonstrated that he 'knew' what he was doing by clicking the wrench on the already too-tight nuts... ::)
I still feel that there must be decent garages out there that are capable of learning the set-up and earning themselves a few quid with the equipment they have
« Last Edit: 23 March 2010, 12:40:06 by jmdavies »
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #11 on: 23 March 2010, 12:42:45 »
All this expensive kit is only as good as the person using it!
ATS at Port Talbot have some good kit, but couldn't use it.
I could, but they obviously wouldn't allow that, and after making a hash of one of our vehicles, I flatly refused to pay up. This was even after the threat of calling the Police by the manager, mind you, I made sure that the car was down off the ramp first!
They were lucky that I wasn't charging them for wasting my time!
I'm happy to follow the experiences of many OOFers, and am planning a trip to WIM meself.
50 quids-worth of diesel is far cheaper than a tyre!
 :y :y :y :y :y
Kaycee
  • Doncaster
« Reply #12 on: 23 March 2010, 12:48:24 »
all the comments are very true especially Marks comments my local tyre fitting place have gone on about the cost of there equipment but when i went to have mine done/checked it read all the angles but they said the camber on Omegas cant be done correctly as it is a funny Setup i laughed in there face and turned on my heel and didnt pay a penny so it shows what they know
If they buy this kit they need to be able to use it and iterpret the adjustments needed especially if Joe bloggs say " Can you sort this its  pulling to left" if they charge 80 you should get that level of expertise but sadly you dont
Seth
« Reply #13 on: 23 March 2010, 12:53:45 »
Yep - we're dealing with monkeys here! >:( >:( >:(
« Reply #14 on: 23 March 2010, 12:55:11 »
There are decent places. All those I have experienced have been independents. ATS / Thick-Fit type places are always a waste of time IME.
You an normally tell, by talking to the guy for 30 seconds about what you want, whether it's going to be worth bothering.
Tony at WIM has the added advantage that he knows the Omega very well, in addition to understanding how suspension systems operate and how that relates to the driving experience.
Very different to the "it's all in the green, mate" approach.
