Author Topic: Water Inside my car.  (Read 2677 times)
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« on: 25 February 2010, 17:20:40 »
Hi guys, My problem is I have water inside my Car on the Drivers side front and rear foot room.
What are the main causes please?
 My heater matrix is ok, and the windows are shut. there seems to be more water in the rear foot room. are there any plugs or such what could cause this?
He who brakes Looses
To old to die young
charlie
  • sunderland
Re: Water Inside my car.
« Reply #1 on: 25 February 2010, 17:40:19 »
leaking door seal or the sunroof drian would be my first port of call :y
« Reply #2 on: 25 February 2010, 17:43:33 »
Tunnie had it in rear footwell, was the clip that holds padding to chassis was missing, leaving hole in chassis.
Ghost
    • 2.6 V6 CDX Estate
« Reply #3 on: 25 February 2010, 18:00:07 »
thanks guts I will have a look in the morning and see if I can find the problem.
To old to die young
mudflap
  • NW London UK
  • My Green Goddess
« Reply #4 on: 26 February 2010, 06:51:36 »
One thing i always clear out occasionally are the drain gutters and leaf traps under the bonnet - trapped wet leaves can cause rusting of the bulkhead and water leaks into the floor wells, also the sills, mudflaps and and wheel arches need cleaning and inspecting for trapped mud which could act as a sponge and eat through the metal.
Another tip is avoid using a hose or garage car wash when washing - high powered hoses will push water through the seals and cause all sorts of trouble, bucket and sponge is the best way, and saves gallons of wasted water.  :y
If it's got tits or wheels  it's bound to give you trouble
Omega_4000_24v
« Reply #5 on: 04 April 2010, 18:07:37 »
Sorry to be dull here but could you please be a little more specific?
I've currently got a similar problem on a 1998 CDX Estate and its not a problem with sun roof or any door membraines either. Its got me stumped! :'(
Opel...Das ist gut, Ja?
« Reply #6 on: 04 April 2010, 18:12:48 »
For the GM carpets there are little clips which hold them matts to the carpet. These should be in the chassis, the other 2 Omegas we have has some fairly solid metal 'bits' here, but mine had a gaping hole  :o
Sealed it with some silicone sealant and some araldite, it had been there for some time, used a Vax to get most of the water out. Its much better than it was, sometimes gets a little damp, but think thats due to the amount of water there soaking back through over time. Certainly main rear foot well carpet is much better.
Look under the car around the foot well area  :y
« Reply #7 on: 04 April 2010, 18:13:39 »
picture of the offending little bugger...
