Author Topic: Problem I think!  (Read 1669 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
Problem I think!
« on: 04 April 2010, 16:05:51 »
I've just bought a 2.5 v6 m reg onle 80000 on the clock cam belt done plugs and leads And full service of oil and gearbox done before purchase but below 3000 revs it's very slow in my opinion after that it's goes great!could there be a fault and if so where do start?
scream if you want to go faster!!!
Re: Problem I think!
« Reply #1 on: 04 April 2010, 16:09:12 »
Who did the cambelt change? I would check the timing settings on the cams, as a tooth or two out will definately affect power. :y
mr ICE man
  • dolgellau wales
« Reply #2 on: 04 April 2010, 16:13:56 »
I don't know as it was done before I bought it but I was told it was someone off here that did it.but as soon as it hits 3000 it is like a different car.
« Reply #3 on: 04 April 2010, 16:16:06 »
check all the multi-rams are working and there is good pressure for them
« Reply #4 on: 04 April 2010, 16:35:17 »
Agreed ^^^^ check multirams :y
« Reply #5 on: 04 April 2010, 16:38:29 »
thirded, check multirams first.
mr ICE man
  • dolgellau wales
« Reply #6 on: 04 April 2010, 17:19:42 »
Will do but how!?need a code read or not?
« Reply #7 on: 04 April 2010, 17:23:37 »
Nope, physically check each one. Front one is down between bag pipes, forget where the back one is, passenger side back of plenum iirc
« Reply #8 on: 04 April 2010, 17:23:46 »
2.5 code read yourself  with a paperclip .. :)
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Multirams make sure the vac pipes and electrical connections are on and firm . :)
http://www.omegaowners.com/forum/YaBB.pl?num=1153840176
HTH
« Last Edit: 04 April 2010, 17:31:16 by entwood »
mr ICE man
  • dolgellau wales
« Reply #9 on: 04 April 2010, 17:54:10 »
Ok done paerclip and got 12 61 71 does that help?
mr ICE man
  • dolgellau wales
« Reply #10 on: 05 April 2010, 11:59:13 »
I've checked the multirams and the back one on the engine is open at tickover. How do I fix it? The front is fine tho....
