Author Topic: Rust Treatment  (Read 1876 times)
rangerman
  • Manchester
Rust Treatment
« on: 05 April 2010, 10:02:50 »
Got a couple of rust spots, anybody now of a decent rust
treatment, i can use, for a start ?
MickAP
  • South Derbyshire
Re: Rust Treatment
« Reply #1 on: 05 April 2010, 10:48:07 »
Kurust......made by the Hammerite co.
You still need to grind, emery (whatever method you use) to get most of the rust off.
Won't stop it but will slow it down. :y
Mick ;)
JezInBrum
  • Birmingham
  • Built for comfort not speed
Re: Rust Treatment
« Reply #2 on: 05 April 2010, 10:56:03 »
Kurust One Coat Rust Treatment Brush On Converter
As previously mentioned.
Have used it myself. You need to do treatment & paint in one go in order for it to work properly
Re: Rust Treatment
« Reply #3 on: 05 April 2010, 11:33:07 »
A very good question! :y :y
I once heard somewhere that there are products the "eat" rust, and replaces it with solid 'metal'.  Is that so?? ::) ::)
Mikes1670
  • Hull
Re: Rust Treatment
« Reply #4 on: 05 April 2010, 11:34:37 »
I have used Loctite Rust Remedy in the past, it is a similar product to the Hammerite Kurust.  It's all about preparation and picking a good warm dry day to do it. Like already mentioned it slows the corrosion process down.
If you have several problem areas I would be tempted to get a quote from a body shop/chips away type outfit. DIY paint repair never meets my expectations usually in terms of a decent finish. I would try and noegotiate a cash job price - I once did this regarding some alloy wheels I had refurbished and they lasted 5 years before they began to deteriorate again.
holtender
  • Suffolk
    • 2.5 CDX Facelift
Re: Rust Treatment
« Reply #5 on: 05 April 2010, 13:55:06 »
The sad fact is unless you totally remove every spot of rust it will return, sometimes in amazingly quick time!
 It is a cancer and there isn't a product on the market that can cure rust.
Re: Rust Treatment
« Reply #6 on: 05 April 2010, 14:13:30 »
Thanks for the info! :y
« Last Edit: 05 April 2010, 14:13:55 by Lizzie_Zoom »
MickAP
  • South Derbyshire
Re: Rust Treatment
« Reply #7 on: 05 April 2010, 16:26:52 »
I agree :y
Mick ;)
