Author Topic: Leak on front of Omega 2.0cd W reg  (Read 1486 times)
JC2000
  • Glossop Derbyshire
« on: 03 April 2010, 21:34:49 »
Hi, I have a W reg Omega 2.0CD and have just noticed a leak coming from the front right of the car under the battery area to the right side of the radiator , I looked at the Rad and could see nothing obvious, I put a small bowl under it after running the car for a while and collected the fluid it was clear cold water. Whereas the car was still warm. Anyone got any ideas?? PS It is not raining!!!!! Many thanks  John
Re: Leak on front of Omega 2.0cd W reg
« Reply #1 on: 03 April 2010, 21:35:41 »
Any hint of screenwash in it?
JC2000
« Reply #2 on: 03 April 2010, 21:40:31 »
Hi Mate , That is what i was thinking as i had filled that up two days earlier but used blue screen wash and the liquid is clear and water tasting i even went and tasted some of the screen wash i had put in it and even a small amount as i collected is definately tinged blue, i have just been out in the dark looking at it could it be something from the air con?
« Reply #3 on: 03 April 2010, 21:50:25 »
a/c drains either side of gearbox bellhousing
JC2000
« Reply #4 on: 03 April 2010, 21:54:07 »
Thanks for that any more ideas anyone, Cheers John
coastie123
  • sidmouth, devon
« Reply #5 on: 03 April 2010, 22:01:31 »
Hi, check out my post under General Car Help called "Leak Noticed Today" The Link is below...
http://www.omegaowners.com/forum/YaBB.pl?num=1269375042/4#4
I do hope it's nothing terminal but it may be a thought as i had Similar symptoms.. :( :(
JC2000
« Reply #6 on: 03 April 2010, 22:09:14 »
Thanks for the info , I am going to have a good look tomorrow, the clear cold water thing is bugging me.
« Reply #7 on: 04 April 2010, 12:20:39 »
It could be nothing more sinister than condensation from the A/C bottle & pipe at the front right of the engine dripping onto pipes/cables beneath & running clear of the engine bay closure tray. It is worth checking this and discounting it as the cause before getting more involved IMO  ;)
JC2000
« Reply #8 on: 04 April 2010, 15:35:49 »
Cheers Phil I think you are right just been on a big run no overheating,runs ace,  no loss of coolant etc and as said left a bowl under it last night , the water collected amounted to about a small yoghurt pot totally clear and tasteless as out of the tap!! Hopefully something of nothing. Cheers John
« Reply #9 on: 04 April 2010, 15:42:18 »
Try running for a couple of days with either the A/C off or ECO  ??? If the problem goes away you've sussed it .. :)
JC2000
« Reply #10 on: 04 April 2010, 15:48:21 »
Hi Entwood , Great idea will do, Many Thanks John
JC2000
« Reply #11 on: 05 April 2010, 19:59:29 »
Hi Entwood, Spot on no more leak , I have always been a worrier!!!!!!!! Many Thanks John
« Reply #12 on: 05 April 2010, 20:02:08 »
Glad to see it was 'something & nothing'  :y
« Reply #13 on: 05 April 2010, 20:03:50 »
Not a problem ... I like to get the odd one right !! .. especially when it's a simple fix !!
JC2000
« Reply #14 on: 05 April 2010, 20:10:21 »
Phil & Entwood , Many Thanks to you both, John.
