Author Topic: Coolant Level  (Read 3333 times)
Ploppy
  • Norfolk
Coolant Level
« on: 03 April 2010, 22:57:10 »
hi,
my coolant level is starting to get low, think this is normal ,,,
However, what coolant should I use, mixture and best place to buy ???
Its for my 2003 Omega 3,2 special...
Thanks Ploppy 8-)
Re: Coolant Level
« Reply #1 on: 03 April 2010, 23:04:04 »
VX own red stuff .. mixed 50/50 with clean water . :)
If you don't know what is in yours at the moment, it is worth draining down, flushing with clean water until clear (including heater side) the refilling with 50/50 Vx red .. it'll last you 2 years and clean and protect your engine .. :)
Best way to buy is with a VX trade card .. :)
« Last Edit: 03 April 2010, 23:04:35 by entwood »
I_want_an_Omega
Re: Coolant Level
« Reply #2 on: 03 April 2010, 23:26:33 »
Be careful, wear goves/wash hands as the coolant is poisonous   :'(
Ploppy
  • Norfolk
Re: Coolant Level
« Reply #3 on: 03 April 2010, 23:58:37 »
Thanks for info... dont need alot so hopefully VX will sell a small bottle,,,,,
Thanks Ploppy :y
Ploppy
  • Norfolk
Re: Coolant Level
« Reply #4 on: 04 April 2010, 00:01:17 »
How do you get a VX trade card??
Re: Coolant Level
« Reply #5 on: 04 April 2010, 00:08:57 »
« Last Edit: 04 April 2010, 00:10:35 by RobG »
Ploppy
  • Norfolk
Re: Coolant Level
« Reply #6 on: 04 April 2010, 00:18:29 »
Thanks !!
Ploppy
Re: Coolant Level
« Reply #7 on: 04 April 2010, 08:29:35 »
Thanks Ploppy :y
You need just under 5l if you are flushing it through - and if the car is new to you, I would recommend doing this, rather than top-ups.
Re: Coolant Level
« Reply #8 on: 04 April 2010, 10:55:57 »
nobody asked where the coolent is going, why is it low? is there a leak? surely?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Coolant Level
« Reply #9 on: 04 April 2010, 18:08:34 »
hi,
Thanks Ploppy 8-)
No its not! :o
Ploppy
  • Norfolk
Re: Coolant Level
« Reply #10 on: 04 April 2010, 23:41:42 »
No leaks that I can find, just usual usage over time I think . ;D
Re: Coolant Level
« Reply #11 on: 04 April 2010, 23:44:09 »
Cars have a closed, sealed coolant system and shouldn't loose water.
You're loosing water ........... HBV, header tank cap, leaking hose, etc
less
  • Hemel Hempstead
    • 2.6 auto saloon
Re: Coolant Level
« Reply #12 on: 04 April 2010, 23:45:19 »
I don't think it is usual to lose water even over time. You probably have a small leak, possibly the heater bypass valve which may be intermittent in nature and often is not visible.
edit - must type faster  :P
« Last Edit: 04 April 2010, 23:46:28 by less »
Ploppy
  • Norfolk
Re: Coolant Level
« Reply #13 on: 04 April 2010, 23:46:53 »
Thanks people,,,will have a closer look !!
Re: Coolant Level
« Reply #14 on: 04 April 2010, 23:48:30 »
HBV can leak or not leak depending on the heat settings selected  or whether the a/c is on or not  ;)
