Author Topic: engine management light  (Read 2895 times)
statuskev
« on: 27 March 2010, 13:27:34 »
Hi there can anybody help please. I have a 2.0 cdx estate and the engine management light  comes on.When you start it from cold all is fine and the light stays out. If started when hot the light comes on and occasionally the engine has cut out but always restarted. Recently i have replaced the idle valve because of the cutting out .Any help would be appreciated
Re: engine management light
« Reply #1 on: 27 March 2010, 13:31:10 »
statuskev
« Reply #2 on: 27 March 2010, 16:28:08 »
Thanks for that i will give it a try when it stops raining
statuskev
« Reply #3 on: 29 March 2010, 17:36:40 »
Tried the paper clip test ,bear with me its my first time.Lamp flashed 10 times then 3 then 4,it then flashed another 10 times then 3 and 3. Hope this helps ,Thanks
« Reply #4 on: 29 March 2010, 18:30:31 »
0340 is a cam sensor fault.
Any other codes?
statuskev
« Reply #5 on: 29 March 2010, 18:33:01 »
Not that i know of but it only does it when the engine is hot.Thanks for the reply
« Reply #6 on: 29 March 2010, 18:38:23 »
There is at least one other code in there, as you said 3 and 3 (which is only a partial code.
Repeat the test until the 0340 code appears for the 4th time (each code repeated 3 times before moving on to next one) :y
statuskev
« Reply #7 on: 29 March 2010, 19:14:57 »
Sorry i think i misread it,checked again and the two codes i think i got are 10 3 3 5 and then 10 3 4 10,thanks for your patience..
« Reply #8 on: 29 March 2010, 19:20:18 »
0335--Crank sensor. 0340--Cam sensor.
statuskev
« Reply #9 on: 29 March 2010, 19:24:44 »
Does this mean that both sensors need to be replaced or can they be cleaned. Is it ok to use the car , many thanks
« Reply #10 on: 29 March 2010, 19:28:00 »
Unusual for both sensors to go at once. On the 4-pot it tends to be the cam sensor and it does sometimes throw other codes. Does it start immediately on the occasions it has cut out. Can you rev the engine past 4-4500rpm
statuskev
« Reply #11 on: 29 March 2010, 19:46:06 »
Engine restarts first and revs ok
« Reply #12 on: 29 March 2010, 19:53:00 »
I`d suspect cam sensor, failing crank sensor would make it a bit of a pig to start especially when hot
statuskev
« Reply #13 on: 29 March 2010, 20:07:09 »
Thanks for that i will try to replace it asap , iit ok to carry on and use the car
« Reply #14 on: 29 March 2010, 20:44:58 »
Still OK to use, but as you rightly said. Replace asap but only use genuine from VX
Page created in 0.047 seconds with 16 queries.
