Author Topic: oil leak  (Read 1209 times)
jordan890
  • manchester
oil leak
« on: 09 April 2010, 19:06:15 »
changed oil leak has now started to run from star scew  on sump is there any thing i can do to stop leak scew is tight :o
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: oil leak
« Reply #1 on: 09 April 2010, 19:08:11 »
Did you use a new "O" ring?
TuBy's new whipping boy.
Re: oil leak
« Reply #2 on: 09 April 2010, 19:08:30 »
New rubber o-ring and/or new sump plug.  The plug with the rubber o-ring is a fairly low torque plug - dead easy to overtighten!!
Edit - must type faster  :-/
« Last Edit: 09 April 2010, 19:09:04 by dbug »
Re: oil leak
« Reply #3 on: 09 April 2010, 19:12:14 »
10nm !
Put o ring in other way up, but ultimately new sump bolt. Don't overtighten
jordan890
  • manchester
Re: oil leak
« Reply #4 on: 09 April 2010, 19:16:28 »
a friend of mine changed the oil for me is the sump bolt a star screw as i am new to this :o
Re: oil leak
« Reply #5 on: 09 April 2010, 19:26:13 »
Yes. Sounds as if the O ring is either missing or not seated in its groove properly. ;)
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: oil leak
« Reply #6 on: 09 April 2010, 19:28:50 »
Dropped into the old oil, that's where the Gnome usually looses mine. ;D
Re: oil leak
« Reply #7 on: 09 April 2010, 19:33:26 »
Buy him one of these then  :y ......
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: oil leak
« Reply #8 on: 09 April 2010, 19:43:18 »
Nah it's more fun making him dig the old one out of the tub. ;D ;D
Re: oil leak
« Reply #9 on: 09 April 2010, 19:51:52 »
 ;D  ;D  ;D  ;D You rotten bugger!  ;)
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: oil leak
« Reply #10 on: 09 April 2010, 19:56:23 »
Thought that was how you trained apprentices.
