Author Topic: HELP! my 2.5 V6 engine is......  (Read 1695 times)
g-unit81y2k
« on: 09 April 2010, 15:53:32 »
tapping or blowing, that kind of noise the mk 3 ford fiesta was commonly unpopular for. its like the tappets or exhaust blowing or something. i just dont no. is this acommon problem with this engine ??? G
Re: HELP! my 2.5 V6 engine is......
« Reply #1 on: 09 April 2010, 15:55:07 »
All the time, or just when cold.
g-unit81y2k
« Reply #2 on: 09 April 2010, 16:05:31 »
worse when cold but still a constant noise. if i rev the engine gently it pairs like a v6 but under force or accelerate whilst driving its tap tap tap tap and it makes me feel as if its a shed. thanks G
« Reply #3 on: 09 April 2010, 16:08:10 »
sounds like a possible exhaust gasket..
g-unit81y2k
« Reply #4 on: 09 April 2010, 16:14:25 »
i thought or i hoped it is just something like that. a friend had the face lift 2.5 V6 a few years back and his did the same only my car seems worse than his. G
« Reply #5 on: 09 April 2010, 16:16:58 »
If it is the exhaust manifold gasket, lets hope its the drivers side one ::)
g-unit81y2k
« Reply #6 on: 09 April 2010, 16:20:43 »
why whats the situation with the near side ?
« Reply #7 on: 09 April 2010, 16:23:30 »
Engine up off its mounts and moved over to allow access ::)
Sixstring
  • Lydney, Gloucestershire
« Reply #8 on: 09 April 2010, 16:26:40 »
Drivers side......ok job, bit of a pain, but quite easy.
Passenger side.......allow at least a whole morning/afternoon, make sure no-one is within earshot (you will use lots of profane language) and make sure you have a good tool set, two trolley jacks, and a piece of plank.
Not my favourite job.
g-unit81y2k
« Reply #9 on: 09 April 2010, 16:28:25 »
wonderful. my luck thats the side. lol
« Reply #10 on: 09 April 2010, 16:28:58 »
You'll need a good 3 to 4 hours to do the driver side ;)
g-unit81y2k
« Reply #11 on: 09 April 2010, 16:42:27 »
thanks for reply and do think it will fix it?
« Reply #12 on: 09 April 2010, 17:14:18 »
If it is the exhaust manifold gasket its not too expensive to get done just make sure you buy a genuine Vauxhall multi layer manifold gasket part No 24416110, manifold to downpipe gasket 90499289, transfer pipe O ring 9128362, 4 x 12992647 Dowty washers for the coolant bridge (You dont have to remove this but I find it makes access easier) and I always buy a few new studs and nuts just incase there's any that have snapped.
g-unit81y2k
« Reply #13 on: 09 April 2010, 21:39:05 »
thanks for all the advice. G
