Author Topic: Re:TD Electric Fans  (Read 1344 times)
350sb
  • London
    • X reg 2.5 TD GLS
Re:TD Electric Fans
« on: 10 April 2010, 16:50:01 »
Hi,
The 2 electric fans in my Omega have been unplugged by the previous owner.The BMW engine has it's own fan.Are the electric ones aircon related or does it provide a source of additional cooling? If it's for cooling,where is this plug meant to be fitted?
Shaun :y
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Re:TD Electric Fans
« Reply #1 on: 10 April 2010, 16:57:36 »
Traktors have 2 electric fans & a viscous coupled one attached to the engine
Some beleive that the viscous is superflous & remove them (LH thread BTW). I have removed mine but will need to monitor the temperature when the summer comes because Traktors seen to het up very quickly in traffic or when pulling hard.
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #2 on: 10 April 2010, 17:08:27 »
The temperature does pick up when flooring it to 4000RPM in 1st and 2nd gear. I would like to reconnect mine.Where do I start?
Thanks
Shaun :y
hoofing it
« Reply #3 on: 10 April 2010, 21:22:26 »
plug them in but mind these fans are connected to the air-con system when it gets hot 90+ the fans kick in to fast running
If the air-con isn't working don't remove the viscous.
unlucky alf
  • worksop, notts
« Reply #4 on: 10 April 2010, 23:29:38 »
very strange to disconnect them if you ask me, unless they were constantly running, in which case id change the sensor/switch on the rad which is on the right side near the top as you look from the front. the viscous fan isnt known for reliabilty.
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #5 on: 11 April 2010, 15:40:51 »
It looks like the aircon compressor along with it's bracket was removed by one of the 8 previous owners.I did remove the plastic panel above the radiator and didn't find any condenser,but there is an aircon switch on the control panel. :y
