Author Topic: Windscreen washers  (Read 2970 times)
ScottieMV6
  • Swinton, Manchester
Windscreen washers
« on: 10 April 2010, 17:08:52 »
My windscreen washers have just stopped working. The tank is full of water/screen wash and the pump can be heard working but nothing coming out of the jets.
Any thoughts?
I'd rather be scared to death than bored to death!!
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
Re: Windscreen washers
« Reply #1 on: 10 April 2010, 17:28:39 »
Have you tried cleaning the rubber grommet where the stop sits as per the maintenance guide?
ScottieMV6
« Reply #2 on: 10 April 2010, 17:38:07 »
Couldn't find anything in the maintenance guides when I looked but have now found it and read it.
Very helpful thanks. I will give that a try :y
jonnycool
« Reply #3 on: 10 April 2010, 17:49:20 »
try looking along the pipe as someone turns the washers on, there may be a leak or kink in the pipe somewhere  :y
« Last Edit: 10 April 2010, 17:50:40 by jmdavies »
amba
  • Medway towns
    • German V6
« Reply #4 on: 10 April 2010, 19:10:59 »
Try seperating the water pipe where it goes into the bonnet area as it should have a joiner..then see if you are getting water to that point....if you are then expect the washer jets on bonnet are blocked...if no water at that point most likely cause is the filter in the water bottle.
Pull out the pump and see if the little black grommet is full opf muck.
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
« Reply #5 on: 11 April 2010, 11:26:04 »
Our feed line split where it bends as the bonnet is opened/closed by the passenger side hinge. A one way valve from Helfrauds (About £5) fixed the problem without the hassle of running a new hose from the pump to the nozzles.
ScottieMV6
« Reply #6 on: 12 April 2010, 15:31:45 »
Thanks to you all for suggestions.
Jonnycool wins ;D - Rubber grommet cleaned and washers work again :y
« Reply #7 on: 12 April 2010, 15:33:23 »
It's a very common 'fault'  :y  :y  :y
« Reply #8 on: 12 April 2010, 15:39:31 »
Possibly screenwash is far too weak ;)
jonnycool
« Reply #9 on: 12 April 2010, 16:30:17 »
Excellent! Glad I could help, makes me feel worthwhile again  :y
ScottieMV6
« Reply #10 on: 12 April 2010, 17:23:14 »
Screen wash refilled at 50/50. Hopefully should stay clear for a while :y
