Author Topic: EGR Swapout  (Read 1401 times)
Humpy
  • Tunbridge Wells, Kent
EGR Swapout
« on: 11 April 2010, 08:53:01 »
Chaps,
I've got a EGR valve to change out as mine is blowing. Do the studs come out ok? Are they know to snap? I guess plenty of WD40 on a cold EGR is the way to go? Thanks in advance.
Humpy
Re: EGR Swapout
« Reply #1 on: 11 April 2010, 09:18:35 »
some wd40 and tapping the studs will help ..and you can also block it with a piece of metal sheet..
« Last Edit: 11 April 2010, 09:20:20 by cem_devecioglu »
sparkyw666.
  • aberdeen uk
  • aka mark w
Re: EGR Swapout
« Reply #2 on: 11 April 2010, 13:00:53 »
blank the egr with a bit of a coke can it get rid of that flat spot and gives better throttle response :y
v6 cam locking kit  member:y
Humpy
Re: EGR Swapout
« Reply #3 on: 11 April 2010, 23:38:52 »
Ok guys thanks for the advice. Trouble is, if I disconnect the EGR valve it brings up the EM light on the dash. Not that it's a problem but if it's on I wouldn't know if something else is amiss.....
Humpy
Re: EGR Swapout
« Reply #4 on: 11 April 2010, 23:40:11 »
Humpy
dont disconnect , just block it..
Humpy
Re: EGR Swapout
« Reply #5 on: 12 April 2010, 07:44:03 »
Ah, I see!
Humpy
Re: EGR Swapout
« Reply #6 on: 12 April 2010, 07:47:33 »
Electrically, it needs to remain connected, but physically you can do anything :y
Road Hog Mad
  • Cheshire
Re: EGR Swapout
« Reply #7 on: 12 April 2010, 14:26:38 »
so blanking off this what difference does it make?
Re: EGR Swapout
« Reply #8 on: 12 April 2010, 14:37:30 »
If its stuck open, it will effectively make it stuck shut, which is a much better state of affairs....
Bent valve
Re: EGR Swapout
« Reply #9 on: 12 April 2010, 20:37:50 »
Whats a swapout? :-/
Page created in 0.026 seconds with 16 queries.
