Author Topic: front brake pipes  (Read 1145 times)
khatton
  • warrington cheshire
front brake pipes
« on: 12 April 2010, 20:00:34 »
hi car failed mot today on front pipes corroded and pipe to rear brakes got old ones off got replacements fitted near side ok but my problem is i now have 2 holes left on the abs thing for the other two pipes but one hole is bigger is this the feed to the rear brakes with it having a bigger hole as the pipes i got have only got normal size screw in ends put on them has the man i took them to made a mistake and is the larger one for the rear feed thanks for any help in advance :-[
Welung666
Re: front brake pipes
« Reply #1 on: 13 April 2010, 14:57:56 »
Sounds like he's used the wrong ends. You need to take them back with the old ones and get him to re-end them.
