Author Topic: 1999 omega dash problem  (Read 1232 times)
scaffy
« on: 11 April 2010, 14:06:21 »
hi ppl, need help with my dash problem, car starts headlight panel in dash lights up even when lights are off,on tick over dash ok, but as soon as u rev or drive all lights on dash comes on,tried fitting new dails, still the same,any help welcome,thanks guys,
I_want_an_Omega
Re: 1999 omega dash problem
« Reply #1 on: 11 April 2010, 14:07:52 »
By headlight, do you mean the blue main beam light?
scaffy
« Reply #2 on: 11 April 2010, 14:10:04 »
yes, m8, engine manigment,abs,battery ,main beam,airbag, sometimes the battery goes flat aswell even tho its only about 4 months old
I_want_an_Omega
« Reply #3 on: 11 April 2010, 14:13:46 »
Sounds like an iffy earth connection to me. You will find a load of them under the battery tray ...........
« Reply #4 on: 11 April 2010, 14:58:59 »
As Rob says above, or could possibly be voltage regulator in the alternator
I_want_an_Omega
« Reply #5 on: 11 April 2010, 15:48:10 »
If you have a voltmeter (preferably digital), measure the battery voltage as you adjust the throttle setting. You can opearate it under the bonnet manually on non-facelift cars. See if there is a voltage that causes the problem to occur/resolve.
The voltage shouldn't drop too far below 13V, if its down at the 11 V or less level then you have a problem with either the battery or alternator - IMHO.
Everything should be steady at upwards of 13 Volts - although it will drop a bit when you crank whilst starting.
Try turning the headlights/heated rear window on, should drop a little, but not too far.
scaffy
« Reply #6 on: 13 April 2010, 18:17:37 »
thanks guys ,but still no joy, tried the earth, thats all good, getting me down at min,if i cant find out whats wrong or if its gonna cost stupied money ,then i think i will just scrap,pity as its a lovely car
