Author Topic: Misfire/Hesitation at 4000 rpm  (Read 4143 times)
ScottieMV6
  • Swinton, Manchester
« on: 14 April 2010, 10:00:12 »
Took my car back to MOT station this morning for retest and on the way there was a misfire/hesitation at 4000 rpm.
Idles and runs fine up to 4000 but then its as if it wants to cut out.
Any thoughts much appreciated :y
I'd rather be scared to death than bored to death!!
Re: Misfire/Hesitation at 4000 rpm
« Reply #1 on: 14 April 2010, 10:09:11 »
Any fault codes?
Is the fuel filter nice and new or old, manky and blocked?
Was the cemblet timing all set up correctly?
ScottieMV6
« Reply #2 on: 14 April 2010, 10:20:08 »
Its still at the MOT station at the minute so can't check for fault codes. Fuel filter could probably do with a change. Cambelt timing all set up correctly as far as I know (though I did it myself following the DVD so could be completely wrong) :D :D
ScottieMV6
« Reply #3 on: 14 April 2010, 18:31:51 »
Got the car back and checked codes. It showed 46 which is SAI (still can't work out what is causing that) and 19. Cleared codes and ran the car again and only 46 came back.
Stuck with this now.  :-/ :-/
« Reply #4 on: 14 April 2010, 18:35:31 »
sensor problem..and cam sensor is #1 candidate imo..
« Last Edit: 14 April 2010, 18:40:40 by cem_devecioglu »
« Reply #5 on: 14 April 2010, 18:41:59 »
Disagree Cem....crank sensor is faulty!
But change the fuel filter
« Reply #6 on: 14 April 2010, 18:48:42 »
ok here is the bet 10 £ from me ;D :y
  • Auckland
    • Mazda MPV
« Reply #7 on: 14 April 2010, 19:46:26 »
Worth checking that the crank sensor plug/connector is firmly in place.
My guess is that (as heat damage to the crank sensor cable has been cited as a cause of crank sensor failure) moving cables around to get the head gaskets changed has accelerated the demise of the cable.
« Reply #8 on: 14 April 2010, 20:10:37 »
Easy money as code 19's NEVER occur without good reason  :y
« Reply #9 on: 14 April 2010, 20:15:53 »
no code 19 mentioned in the original post :-?
ok then 10 £ is yours.. :y
« Reply #10 on: 14 April 2010, 20:17:51 »
No but, scottie mentioned a 19 in his...... ;)...which is crank sensor incorrect signal
« Reply #11 on: 14 April 2010, 20:21:22 »
thats not fair ;D
anyway you will get your tenner.. check your pm
by the way hesitation over 3500-4000 rpm is %90 cam sensor (I double check it) :y
Yes, camsensor will kick in limp home mode and apply a 4K rev limit, so will knock sensors (more common to see these damaged).
Never yet seen a V6 cam sensor actualy fail but, have seen them damaged due to incompitence
« Last Edit: 14 April 2010, 20:24:03 by Mark »
« Reply #12 on: 14 April 2010, 20:46:26 »
So why have I got one with (yet another) new sensor?
« Reply #13 on: 14 April 2010, 21:17:08 »
Have you tried re-fitting it.....particularly at the block end
ScottieMV6
« Reply #14 on: 14 April 2010, 22:02:22 »
So are we saying its crank sensor or cam sensor. I;ve always thought that 19 was crank sensor but Cem's description sounds exactly like my symptoms. :-/
