Author Topic: Changing Water Pump  (Read 1625 times)
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
Changing Water Pump
« on: 14 April 2010, 11:58:02 »
Is it as easy as it looks on the 2.5 v6?
Remove air intake duct, remove SAI metal pipe, loosen pully bolts, remove aux belt, remove pully and water pump.
any special tools required?
Daily drive     - 1997 2.5 CD Auto - 25-35 mpg
Weekend Fun - 2003 RX8 231      - 14-18 mpg
Re: Changing Water Pump
« Reply #1 on: 14 April 2010, 12:36:18 »
Is it as easy as it looks on the 2.5 v6? ....
Yes  ;)
No  :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 14 April 2010, 12:40:03 »
You are going to get anti freeze all over your Cambelt though.
How much longer is it before you need to change the Cambelt & Tensioners? maybe worth thinking about doing the lot at the same time ;)
« Reply #3 on: 14 April 2010, 13:15:10 »
Agreed with Daz - if it's less than 20k till it's due, just do the lot IMHO.  :y
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
« Reply #4 on: 14 April 2010, 13:16:44 »
Thanks ppl.  Will be doing it friday (weather permitting).
Cambelt & tensioners were done about a year ago so not needed doing.
Will have to try and get some sort of plastic shield in place to protect the cambelt then.
« Reply #5 on: 14 April 2010, 13:18:26 »
Just swill the belt with clean water, it'll be fine. Timing belts live in far harsher enviroment than the front on an engine.  ;)
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
« Reply #6 on: 15 April 2010, 09:45:22 »
just to bump this back up with another question....
Stripped all out and changed the water pump last night (was light and good weather so thought I better get on with it), put all backtogether, just waiting for a new aux drive belt BUT,
Should I have sealed water pump with VX grey sealer as used on oil cooler plate or should the o ring suffice???
« Reply #7 on: 15 April 2010, 09:47:13 »
The "O" ring will be fine.  :y
