Author Topic: Inlet manifold torques and 'spare' plugs...  (Read 2923 times)
« on: 16 April 2010, 23:54:28 »
Hi All,
I've been slowly putting everything back together after doing the cam cover gaskets, but can't find the torque settings for the inlet manifold and as I can be abit enthusiastic when tightening up bolts I don't want to go twisting them off! Can't spot them in the guides... ::)
Also I've a 'spare' 3 pin plug coming from the back which after searching the maint. guides, I think is the crank sensor plug...   Trouble is I can't find the other end  :-[  :-[ :-[
Thanks in advance!!! :)
Re: Inlet manifold torques and 'spare' plugs...
« Reply #1 on: 16 April 2010, 23:58:38 »
inlet manifold is 25 or 30Nm if i remember right, 3 pin plug, not for the ICV is it?
« Reply #2 on: 17 April 2010, 00:06:18 »
Hi Tunnie, thanks for the torques...
Well the plug does look like it fits onto the ICV but it comes from the back of the engine, unless I've somehow laid it out of the way and then bolted the inlet manifold over it :-/
« Reply #3 on: 17 April 2010, 00:10:20 »
don't quote me on the torques, think its those. I have little trouble getting them off, so they can't be that high!  ;D
« Reply #4 on: 17 April 2010, 00:13:03 »
Righto, I've already tightened them, but I was abit nervous of twisting them off  ::) ::)
« Reply #5 on: 17 April 2010, 01:11:58 »
20nm for manifold to divider and 8nm for plenum to manifold. Sounds like you're close enough. ;D
Boatboy
  • St Albans
« Reply #6 on: 17 April 2010, 09:55:45 »
Is the plug for the rear multiram at the back of the plenum?
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
« Reply #7 on: 17 April 2010, 10:22:48 »
No I don't think its the mulitiram plug as there is another one, and looking at engine pics on here it looks like the crank sensor plug, not sure why I disconnected that tho... :-/
I just hope I don't have to take the inlet manifold off again to solve it, as thats a nightmare, lots of LPG stuff in the way!! :( :(
Mind you, at least I know the torque settings now if I have to!! Thanks Kevin!! ;D ;D
« Reply #8 on: 17 April 2010, 10:26:07 »
If it looks like a crank sensor plug, it could be an old one that hasn't been removed, i've come across this a few times ;)
« Reply #9 on: 17 April 2010, 10:41:37 »
Trouble is, it does look like it would fit in the ICV..... but its coming from the back of the engine..... :-/ :-/ and I can't find the ICV plug  :( :(
Where would I find the connector for the crank sensor? Does it come from the main loom in the cable tray?
« Reply #10 on: 17 April 2010, 12:28:43 »
ICV has two connections, if it has 3 then its probably an old crank sensor plug
« Reply #11 on: 17 April 2010, 14:21:58 »
No, its at the rear of the engine around the dis pack area. The ICV connector should be coming out of the cable tray half way along it unless you had the cable tray off and not routed it properly.
« Reply #12 on: 17 April 2010, 15:57:53 »
Looks like it is indeed an old crank sensor plug, as I spotted an identical plug and connector and the wire goes down the right side into the depths!!  :)
However, it was only after removing the inlet manifold again and all the LPG gubbins that I spotted it!! :'( >:(
« Reply #13 on: 17 April 2010, 16:18:13 »
The law of sod ::)
At least you'll know for next time ;)
« Reply #14 on: 17 April 2010, 16:22:58 »
Oh and found the ICV plug as well, but actually meant the plug that goes into the front of the throttle body on the near side ::) ::)
The plenium is back on, trouble now is that the front cable tray bracket is in the way of the water pipe..... :( :( :(
Thought I'd come in for a cuppa, but back for more fun and games now ::) :D ;D
